Hi I have fitted a big brake kit to my 1994 NA.The std 14 inch space saver wheel does not fit over the calipers,15 x 7 inch wheels.Are all MX5 space savers 14inch and does anyone have any "polite" suggestions
WASP
Big Brake Kit
- bruce
- Vehicle: NA8 - Turbo
Big Brake Kit
I don't think any spacesaver will fit over non-standard brakes. You might have to make do with a can of tyre goo.
Big Brake Kit
WASP wrote:Are all MX5 space savers 14inch
The NB space saver is larger than the NA space saver, but I'm not sure if the NB8B space saver is larger than the NB8A space saver given the increase from 15" to 16" rims on the later model. However, you might find the NB8A space saver is sufficiently large enough for your situation.
