The recommended tyre size for my SE are 205/40/17. Can I fit 215/40/17, this might just leave enough rubber to guard the mags from the curb.
David
Tyes for 04 SE
- morton
- two40
Tyes for 04 SE
I'm running 215 rear and 205 front. No issues whatsoever.
- MINX
Tyes for 04 SE
Hi David,
Yes, I find 215/40/17 perfect. (std wheels and suspension)
No rubbing or problems.
It also fixes the speedo error. Spot on.
Stuart
Stuart
- two40
Tyes for 04 SE
Is it best to run 205 front and 215 rear? I was thinking of going 215 front and back so I can rotate. Any problems with this idea?
- MINX
Tyes for 04 SE
Run same size all round
- morton
Tyes for 04 SE
Thanks for the feedback guys, next tyres will be 215/40/17. Any suggestion on brand? would like a good all round tyre, good grip, good mileage and as quiet as possible, don't want much hah.
Cheers and Happy New Year,
David
David
- MINX
Tyes for 04 SE
Lots of threads and COWs on what type of tyre.
Best to use the search function and have a read through those.
Lots of variables - $ / Driving Style/ DD or track or both / Mileage you expect etc etc etc
Also, if you update your sig showing your location, you might find some one near you to help.
- morton
Tyes for 04 SE
Thanks Minx, just updated my profile.
Cheers.
Cheers.
- MINX
Tyes for 04 SE
Arh Adelaide.
We will be down your way at Easter for Natmeet.
- Fuzzlet
Tyes for 04 SE
George - I used to run 215 all round, and used to get a bit of a rubbing noise when on full lock, hence the 205s on the front when u bought it...having said that, it still made that noise...
- two40
Tyes for 04 SE
Ahh I see. Thanks. I've not noticed it tbh. I've always been scared of the power steering noises when on full lock.
I'll check it out though.
Users browsing this forum: No registered users and 113 guests
