Hey all
I am looking at getting some underbody braces for the MX, but I have found that a few of them wont fit because my car doesn't have the brackets for the underbody braces, as the later NA8's did. I am not sure about this cusco one.
If someone has a cusco front lower control arm brace attached to their car, could you please send me some photos of the attachment points, to see if I need those brackets or anything.
cusco lower control arm brace
- bensale
I'm pretty sure with those style of braces you slip a threaded plate into the control arm and position it to line up with one of the pre drilled holes in the control arm, then bolt the brace on.
I'm looking at fitting something like that to my car to, a friend of mine Cheyne had one fitted to his car and I was very impressed by the difference it made.
Once you finally get to it there are a couple of photos in the first post of this thread viewtopic.php?f=57&t=32276&hilit=diary
www.othersideproductions.com
