15x7 35mm offset on a NA?
jerrah
Postby jerrah » Thu Nov 19, 2009 12:57 pm
Has anyone tried fitting 15x7's with 35mm offset (or less) on a NA? Have you had any problems with rubbing?
Any modification of the guards required?
1991 MX5
StanTheMan
Postby StanTheMan » Thu Nov 19, 2009 1:02 pm
should be sweet. even if its been slammed with a 205/50 series
jerrah
Postby jerrah » Thu Nov 19, 2009 1:08 pm
I've had rubbing with 16x7 with 40mm offset with 195/50/16 and 205/50/16...
I was going to use 195/50/15 as it's closer to the stock size.
1991 MX5
pcmx5
Postby pcmx5 » Thu Nov 19, 2009 1:10 pm
I have 15x7 38 et and they are fine< i run 195/50,;Johnd has 15x7 35et and runs 205/50 and again no drama.
Both cars are about 330mm from hub centre to guard from memory.
Peter
Postby Jeo » Thu Nov 19, 2009 1:13 pm
I've got 15x7 +25 195/45 on mine now and it isn't even close to rubbing.
How low are you/whats your hub center to guard measurement?
jerrah
Postby jerrah » Thu Nov 19, 2009 1:16 pm
Car came with King Springs and set to the middle perch on Koni Sports.
I'll measure hub to guard tonight.
1991 MX5
StanTheMan
Postby StanTheMan » Thu Nov 19, 2009 2:05 pm
these are 15x6.5 with Azenis Rt215 205/50x15 35mm offset
koni & king on the lowest setting
a 15x7 would come 6.15mm further out. Its hard to see but my fenders have not been modified in fact I still have the inner guard fitted on that pic.
so is it possible your offset is a bit different?
broady
Postby broady » Thu Nov 19, 2009 2:25 pm
I had 16x7.5 +35 with 205 series rubber with no problems on my NA
人馬一体 NA8
6/5/2010
jerrah
Postby jerrah » Thu Nov 19, 2009 3:33 pm
My car isn't as low as STM.
I have rubbing on my front guard liners from my last track day with 185/60/14's, I wonder what's happening.
1991 MX5
Locutus
Postby Locutus » Thu Nov 19, 2009 3:49 pm
something isn't right. 185/60R14 is the factory tyre size for an NA8 so there should definitely be no rubbing despite the 10mm change in offset.
have a look under your car or get it checked out.
jerrah
Postby jerrah » Thu Nov 19, 2009 4:32 pm
Mmm, might need new bump stops.
1991 MX5
Postby orx626 » Thu Nov 19, 2009 11:35 pm
jerrah wrote:Has anyone tried fitting 15x7's with 35mm offset (or less) on a NA? Have you had any problems with rubbing?
That's the exact wheel specification I use on the track, Jeremy. Shod with 205/50 R15 Toyo R888's there is no rubbing and my guards are unmodified.
Adam_NAclubman
Postby Adam_NAclubman » Fri Nov 20, 2009 10:14 pm
I only juuust had to roll my fronts with 15x7 +17's running 195's
