just out of curiousity, how much clearance do we (NB8a) have before a wheel/tyre will start to rub the strut/suspension?
there's about 25-30mm before a wheel will start to catch the guard (assuming no camber) but what about inner clearance?
just been lookign at wheels/offset etc, and basically I've found one that I like.
specs are:
15x6.5 +35 (+35 is the lowest offset for that wheel apparently)
stock is 15x6 +38 (offset may be slightly different?)
anyway, according to my calculations the new wheel will do teh following:
be 3.35mm closer to the suspension (ie: 3.35mm less inner clearance)
and sit out 9.35mm (ie: 9.35mm closer to the guard)
I went to have a loot the other day, but cant see any way of measuring the inner clearance accurately.
Strut/suspension clearance?
- philz
- Wheel guru
Assuming the original nb8A wheels are +38, I'm pretty sure they are +40 or 42.
But anyways, you calculations are correct.
You have extended the wheel are 9mm.
and closer to the inner strut by 3mm.
the nb8a wheel is +40, you will only be closer to the strut by 1mm, and sticking out 11mm.
Don't worry you won't scrap the suspension, unless you are running like 9"wide +36 or similar.
And if you upgrade to coilovers you will have more clearance.
Users browsing this forum: No registered users and 128 guests
