bump stops???
- Vehicle: ND - 2
bump stops???
hi all.
just wondering if you could reccomend some bump stops?
i have heard about the fat cat ones but is their site the only place you can get them?
are there any other kits that are known of locally? price??
cheers
Kris
cheers
Kris
- Matty
bump stops???
The Fat Cat ones are the same as the Ground Control ones (the 36mm FCM stop is a cut down 56?mm GC one)
bump stops???
Whats do bump stops do?
Great looking 02 BLACK NB8B, Tein S Tech Coils, Whiteline Adjustable Sways F&R, Carbing Alloy Rear Strut Brace ;)
- sliq
bump stops???
matt9111 wrote:Whats do bump stops do?
it gives you more travel for a smoother ride
bump stops???
I run AGX"s with Kings Springs. When I fitted FCM Bumpstops the difference was AMAZING, more consistant handling, far better ride,worth every cent
- sliq
bump stops???
matty do you still have those bilstein bumpstops?
- bruce
- Vehicle: NA8 - Turbo
bump stops???
sliq wrote:matt9111 wrote:Whats do bump stops do?
Huh? That does not make sense. I thought they were rubber things to limit the the level the car bottomed out at?
- sliq
bump stops???
bruce wrote:Huh? That does not make sense. I thought they were rubber things to limit the the level the car bottomed out at?
http://fatcatmotorsports.com/FCMstops_36.htm
* Benefits
Gain >1" total bump travel vs. factory 90-97 and 1/2" before bump stop engages (compared to 46mm linear). Lets your stiffer springs do their job!
*Compresses 3 mm less overall vs. 46mm to reduce front tire rubbing - a built-in spacer
*Force increases linearly to ensure predictable handling
that's the one i was looking at before
- GS
bump stops???
sliq wrote:bruce wrote:Huh? That does not make sense. I thought they were rubber things to limit the the level the car bottomed out at?
http://fatcatmotorsports.com/FCMstops_36.htm* Benefits
Interesting... FCM have changed their line up. They used to recommend their 54mm bump stop for NA's with stock ride hight, and the 46mm for lowered springs.
1989 NA6
- Vehicle: ND - 2
bump stops???
yeah they sound the goods.
...can you get them in australia?
what about the ground control ones?
anything at all available local?
- Garry
bump stops???
That's all they do on most cars but they do a bit more work in an MX5, especially in an NA. Due to the short suspension travel in the MX5 the gurus at Mazda used the bump stops to aid in upping the spring rate near the end of the suspension travel. Changing the bump stops can change the amount of travel and the spring rate and therefore the ride.
- bruce
bump stops???
Cool. From the pictures I can see the stops are shaped to 'assist' the spring.
- Vehicle: ND - 2
bump stops???
buz 138 wrote:yeah they sound the goods.
bump stops???
I would not bother with different bump stops and sort out the actual problem, which is the suspension travel reduction when lowering the car. If you are hitting the bump stops a lot than you need to change the top mounts.
On my car, sorting out the top mounts = 1.5 seconds over a 2km sprint track
http://picasaweb.google.com.au/lh/photo/2LtFxpg7HxnC3LQeWozcYQ?feat=directlink
http://picasaweb.google.com.au/sigratton/MX5#5367478424833767666
The idea is to give 20mm more strut travel = 35mm more wheel travel. My mounts are apexi with koni dampers, I had to get some bushes made (see above) Flyin Miata do them too. I re-used the standard bump stops, the car is totally different, no more bouncing around and unpredictability.
http://www.flyinmiata.com/index.php?dep ... %20%2010MM
Si.
Si.
NA6 B6T
- Vehicle: ND - 2
bump stops???
thats the info i want!!!
i think i'll order a pair of these and some of their bump stops for the front in the next couple of weeks!
there was a pair of apexi's for sale on here/ebay a little while ago and i should have snapped them up then.
flying miata are USA yeah??... all orders from there?
thanks again for that Si.G!!!
cheers
kris
cheers
kris
Users browsing this forum: No registered users and 17 guests
