going to install some EBC greenstuff pads tomorrow night.
figure i might as well give the pistons a good greasing and check everything over while i'm at it.
what sort of grease do you recommend and why?
i've got some high temperature bearing grease in the shed, probably what i'll use if i'm not advised against it.
[BRAKES] slider pins - grease?
- JBT
Use brake grease. http://tinyurl.com/lxcct3
- corners
- Vehicle: ND - Supercharged
- corners
Also I just went to the local brake shop told them what I wanted and they just gave me a small amount of grease to use!
bursons had nothing silicone based. guy told me to use HTB grease. eh. slippery stuff is slippery stuff to me.
- JBT
Why bother asking our advice then Use petroleum based grease on your brake system at your peril.
Users browsing this forum: No registered users and 138 guests
