Help, need advice reinstalling NA6 brakes !!!!!!!!!!
michael
Postby michael » Mon Jul 20, 2009 8:37 pm
All,
I bravely decided to completely clean out the brake calipers and pushed the piston out of the caliper and cleaned everything up. But now I can't get the piston back into the caliper through the rubber seal on the caliper. I lubricated the seal with rubber grease but the seal won't slip over the back end of the piston to enable the piston to be pushed back into place.
Anyone got any tips how to reinsert the piston through the seal without damaging the seal.
Any advice would be appreciated.
Regards
Michael
tbro
Postby tbro » Mon Jul 20, 2009 10:27 pm
Oh dear!!!!!!! :roll: :roll:
Check your pm, where in Brissy are you.
Terry
wun911
Postby wun911 » Mon Jul 20, 2009 11:30 pm
I had a go at getting the piston out but failed how did you remove the piston on the rear calipers??
every ounce counts
michael
Postby michael » Tue Jul 21, 2009 9:25 am
wun911,
At this stage I have only done one of the fronts. I took off the caliper and then had someone gently press the brake pedal so that the pressure slowly pressed out the piston.
Regards
Michael
