Brake upgrades bolt in or slight mods
little decks
Postby little decks » Thu Jul 02, 2009 8:02 pm
My old man actually has an AP racing kit that he designed for the MX-5 specifically.
http://mx5cartalk.com/forum/download/file.php?id=948&mode=view
Fatty
Postby Fatty » Thu Jul 02, 2009 8:10 pm
standard NB8B brakes will bolt straight on and fill up a lot of that empty space. click on the links of the forum sponsors below coz they would have second hand parts in stock i reckon and at least one of them shuld be able to help you out.
Postby Okibi » Thu Jul 02, 2009 11:22 pm
little decks wrote:My old man actually has an AP racing kit that he designed for the MX-5 specifically.
I'd love those :mrgreen:
little decks
Postby little decks » Thu Jul 02, 2009 11:28 pm
Yeh they are pretty awesome, but they are a front only, and its all incredibly high quality, and with that quality comes the cost i guess.
wun911
Postby wun911 » Fri Jul 03, 2009 12:16 am
I dont think the NB8B calipers fill out the 17" wheels all that much...
you may want to get some fake brembo caliper covers on e bay around 32 dollars.
every ounce counts
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Jul 03, 2009 9:46 am
brembo kit will fill it the best - 317mm from disk i think. all the other kits are a bit small or rubbish chinese stuff. that ap kit is very very nice. I am yet to receive my ap racing kit but its the ap racing factory kit and is a bit smaller then little decks dads version. I have done a massive amount searching for brake kits and it really does depend on budget. google it and you will fine quite a lot of options for mx5/miata big brake kits. but have a look at the brembo kit.
Postby bruce » Fri Jul 03, 2009 10:58 am
It would be easier and cheaper to go back to smaller wheels. The expense of any brake upgrade for aesthetic reasons is a total waste-I think the brakes are capable to handle the fire breathing 100+ hp engine.
mx52nv
Purple Porsche Eater
Postby mx52nv » Fri Jul 03, 2009 1:01 pm
bruce wrote:It would be easier and cheaper to go back to smaller wheels. The expense of any brake upgrade for aesthetic reasons is a total waste-I think the brakes are capable to handle the fire breathing 100+ hp engine.
QFT.
When you have actually gone over the 200 rwhp mark then look at a balanced front and rear brake upgrade. On a NA6CE, a 17" wheel can look good with some lowered suspension but will never handle as well as on lighter 15" or 16" wheels with 6.5" to 9" widths. But it is your car and in the end, what you like goes. :mrgreen:
Les
Postby sliq » Fri Jul 03, 2009 2:53 pm
little decks wrote:Yeh they are pretty awesome, but they are a front only, and its all incredibly high quality, and with that quality comes the cost i guess.
just out of curiosity, how much for these puppies?
SPy vs. SPy
Postby SPy vs. SPy » Fri Jul 03, 2009 3:05 pm
I'd expect somewhere between $2500 ~ $4000 depends on many things, the calipers themselves will account for a sizable chunk.
Fuzzlet
Postby Fuzzlet » Fri Jul 03, 2009 5:44 pm
I was quoted $3 - $4k for the parts (price difference is for pad choice). It comes with:
2 calipers
2 dba 5000 series slotted rotor
2 alluminium hat (anodised in your colour of choice)
2 dog bones to re-align the caliper to the hub (again anodised in your colour of choice)
2 adr approved brake lines
1 set of pads
and you will also need 8 longer wheel studs
wun911
Postby wun911 » Fri Jul 03, 2009 6:32 pm
I know lotus has AP racing calipers front and Brembos rear calipers. I hear the pads are hard to find and expensive but at least you have acess to DBA 5000 series rotors...
every ounce counts
little decks
Postby little decks » Fri Jul 03, 2009 7:00 pm
wun911 wrote:I know lotus has AP racing calipers front and Brembos rear calipers. I hear the pads are hard to find and expensive but at least you have acess to DBA 5000 series rotors...
the caliper dad uses is actually bigger than the lotus AP caliper...
he chose this for several reasons,
-it matches the fluid diplacement of the standard caliper so the pedal is virtually identical
-there is an enormous selection of pads that fit these calipers
-AP quality is second to none
little decks
Postby little decks » Fri Jul 03, 2009 7:03 pm
Fuzzlet wrote:I was quoted $3 - $4k for the parts (price difference is for pad choice). It comes with:
2 calipers
1 set of pads
this is all correct, but the price is $3300 incl. GST
however this does not include pads as there are different options in brand/quality etc
Postby sliq » Fri Jul 03, 2009 7:37 pm
you'll probably fly through your windscreen with it's stopping power :twisted:
