Hey all,
How much camber can you get from stock adjusters on NB8a suspension ?
I just want to know if i need camber arms before i go for a wheel alighnment...
cheers WAz
How much camber ?
- wazman
How much camber ?
ilovedrift.com
How much camber ?
I could get -1.5 degrees on the front of mine...
How much camber ?
Enough
-2.5 at the rear for me and -2 at the front.
How much camber ?
wazman wrote:Hey all,
cheers WAz
Depends on how low you want or do run the car. The lower the more neg camber..
- 16bit
How much camber ?
what he said ^^. i have a bit over 2 in the front a bit over 3 in the rear. you will wear out tyres quicker but apparently it is a 'faster' setting. I am yet to prove it but we will see, at least it looks cool!!
- 16bit
How much camber ?
oh i am on full low with tein ss.
How much camber ?
rascal wrote:wazman wrote:Hey all,
cheers WAz
In wazmans case, its to fit the wheels comfortably too ;)
How much camber ?
16bit wrote:what he said ^^. i have a bit over 2 in the front a bit over 3 in the rear. you will wear out tyres quicker but apparently it is a 'faster' setting. I am yet to prove it but we will see, at least it looks cool!!
I dont see why you need any rear camber? you have plenty of room with those flares and could fit a -15 wheel in there with no camber. the less camber at the rear = bigger contact patch = more grip.
How much camber ?
MXHEVN wrote:I dont see why you need any rear camber? you have plenty of room with those flares and could fit a -15 wheel in there with no camber. the less camber at the rear = bigger contact patch = more grip.
More grip only in a straight line...
Cornering requires extra negative camber to compensate for roll. Have a look at any decent race car and you'll see neg camber aplenty. They dont do it just for looks.....
How much camber ?
rascal wrote:MXHEVN wrote:I dont see why you need any rear camber? you have plenty of room with those flares and could fit a -15 wheel in there with no camber. the less camber at the rear = bigger contact patch = more grip.
with a car like 16bits, you'd want as much grip as possible.
- 16bit
How much camber ?
yeah it grips plenty well in a straight line as it does not have as much torque as a turbo and the r1r's are quite good on the road. in corners its as brilliant as any mx5 really - that camber will ( and should) only make a difference on the track I would think. you should not NEED it on the street if you are going the speed limit. i got the settings as a combination of recommendations from this forum and emilio from 949 racing. I think I need new bushes to improve feel just that bit more. which brings me to another point - with offset bushes the race guys report as much adjustment as -6 pending ride height etc.
How much camber ?
The bushes are only -2 extra so would only change from the factory setting of -1 to +1 to a -3 to -1. (again assuming ride height is constant between fitting the bushes)
The -6 is when the mount points are relocated, or aftermarket arms used..
- 16bit
How much camber ?
ic, well you can get them from 949. only 1750usd plus delivery - bargin!
