Check this lift kit
Check this lift kit
I have managed to overcome the problem of an Mx5 being to low to use as a rally car
Check the pics!
Check the pics!
Stay Sideways
Check this lift kit
Did you have to do much work to get the suspension to work in the new angles/planes?
Check this lift kit
No not realy, I just use some off-set bushes in the lower arms at the front to get good negative camber.
Stay Sideways
- Hammer
Check this lift kit
Awesome! First time I've seen an MX5 used as a rally car.
Where do you compete?
- Vehicle: Non MX-5
Check this lift kit
did murray coote play with the suspension?
- corners
- Vehicle: ND - Supercharged
Check this lift kit
project.r.racing wrote:did murray coote play with the suspension?
Possibly but I dont imagine so. The sponsor on the side is in VIC
http://www.tracksidetyres.com.au/
Check this lift kit
It was running bilsteins last time I spoke to him..
Check this lift kit
The shockers are Bilstein, springs are King and the set up is my design with a little help from true steer fabrication for the fabrication works.
Stay Sideways
Check this lift kit
Ps. I compete in Victoria in the Victorian Club Rally Series and will soon try the Victorian Rally Championship.
Stay Sideways
- PUR157
- lightyear
- Infinity & Beyond
- Vehicle: NA6 - Turbo
Check this lift kit
Hi, i saw your car on the trailer at nagambie. Looked like you had fun going by the amount of mud on it. How did you go??
Check this lift kit
16th outright, 5th in under 2 litre class (C) with a sick navigator, had a ball was heaps of fun.
Stay Sideways
- Woo
- Vehicle: 10AE - Turbo
Check this lift kit
mx5rally wrote:16th outright, 5th in under 2 litre class (C) with a sick navigator, had a ball was heaps of fun.
Yep, it was heaps of fun, well done picking your way up the field
Hopefully this link will have some pics of the service crew and the mud
http://www.facebook.com/album.php?aid=89789&id=551428044&l=b51bba53a7
Bazz
Very slightly modified 10AE #2562 ..... one of 149 in Australia
Race what you brung ..... And hope you brung enough
