Hey
I bought some second hand Tein Flex's which I am gonna install soon, just wondering if someone knows of a manual or guide which shows how to adjust, height, spring tension and rebound?
Thanks
Tein Install Guide or Manual
- corners
- Vehicle: ND - Supercharged
- philz
- Wheel guru
- corners
Thanks Philz!!
- corners
Also can anyone tell me that springs the flex comes with?
The ones I have have a light grey spring with Swift stickered on the side
- philz
- Wheel guru
You have swift springs. which are aftermarket springs for aftermarket coilovers.
They are usually replaced for a more stiffer spring rates.
Oh and normal stock Tein flex are 7/6
also, having done the suspension 4 times on 5, easiest way to do the suspension is the "long bolt" method. basically take out the long bolt that holds the upper wishbone of the fronts, and take the suspension out, rear is a lot easier... big forum should have some detailed instructions..
- sliq
silvermiata wrote:also, having done the suspension 4 times on 5, easiest way to do the suspension is the "long bolt" method. basically take out the long bolt that holds the upper wishbone of the fronts, and take the suspension out, rear is a lot easier... big forum should have some detailed instructions..
agreed
with regards to the rear suspension, it is easier but you must remove a bolt on, erm...the wishbone...such that you can push it down and replace the coil. I found it a bit more involved in my NB8B that others experienced for their NA's
- corners
All installed and seems ok.
Did anyone have any issues with whiteline front sway bar hitting the shocks???
