Shafted!!!
Posted: Sat Apr 25, 2009 9:33 pm
I recently purchased some ApexI Pillow upper mounts for the rear end.
They give me quite a bit more suspension travel before hitting the bumpstops. So, today I needed to remove the nut off the driver side rear damper. I managed to screw up the thread on the damper shaft, and then took it a step further by snapping the top of the shaft, including the adjustment knob.
I have sent Fulcrum Suspension an email to see if they can replace the shaft for me.
J
J
