TEIN vs Gaz
green_comet
Car Detailing Guru
TEIN vs Gaz
Postby green_comet » Mon Apr 20, 2009 2:17 pm
I would go the GAZ coilovers over the Teins. The GAZ have adjustable damper for bump and rebound, and the entire shock body is threaded, so you can get alot lower than the Teins. The Teins that are just basic shocks that you can adjust your height up and down. I don't even thing you can adjust dampening at all.
I would pay the little extra and get the GAZ, they look better.
Here is another place you should look at ordering them from, they are currently out of stock, but they should get sets in soon. You will save a bit of cash ordering from UK..
http://www.mx5parts.co.uk/product_info.php/products_id/1066
It works out to be:
Goods:€479.68
Del.:€148.12
To Pay: €627.80
Which works out to, 627.80 EUR = 1,137.94 AUD delivered to your house, a saving of $262.06 over MX5 Mania...
I think im going to get myself a set, with the Krudd money.
*EDIT* Having said all this though, I have been reading up and a few people have been having issues with the Gaz coilovers..
http://forum.miata.net/vb/showthread.php?t=311941&highlight=gaz+coilovers
http://www.pistonheads.com/gassing/topic.asp?h=0&t=624041&d=0 *EDIT*
R
philz
Wheel guru
TEIN vs Gaz
Postby philz » Mon Apr 20, 2009 2:37 pm
Go Tein.
Matty
TEIN vs Gaz
Postby Matty » Mon Apr 20, 2009 5:47 pm
green_comet wrote:I would go the GAZ coilovers over the Teins. The GAZ have adjustable damper for bump and rebound, and the entire shock body is threaded, so you can get alot lower than the Teins. The Teins that are just basic shocks that you can adjust your height up and down. I don't even thing you can adjust dampening at all.
Having the whole body threaded is useless if (for example) the perch starts interfering with the driveshaft.
Adjustability is only good if it retains a decent damping curve.
Coilovers are only good value if they come with good spring rates that suit your goals. (from what I've seen, neither option would satisfy me)
I wouldn't buy coilovers on how they look. :shock:
Teins have a reasonable track record, GAZ are a but of an unknown quantity.
In a nutshell, there is a lot more to picking a coilover setup than what features it has.
Matty
TEIN vs Gaz
Postby Matty » Mon Apr 20, 2009 5:50 pm
green_comet wrote:Which works out to, 627.80 EUR = 1,137.94 AUD delivered to your house, a saving of $262.06 over MX5 Mania...
Have you factored in GST and duty on that? prepare for another ~25% reaming...
wazman
TEIN vs Gaz
Postby wazman » Mon Apr 20, 2009 9:23 pm
Anyone using HSD coilovers ?....... I'm a former nissan silvia guy and this brand is very popular in the nissan's...... a friend has a set in his rx7 FC, says they are great.....
they only make em for the Na mx5 though..... :cry: clicky the link to have a look.
http://www.otomoto.com.au/HDSystems/
ilovedrift.com
philz
Wheel guru
TEIN vs Gaz
Postby philz » Mon Apr 20, 2009 9:44 pm
Wow, so they finally bring in the HSD coilovers for the mx5.
NA coilovers work on NB and vice versa.
