Rims
philz
Wheel guru
Rims
Postby philz » Wed Apr 15, 2009 11:30 am
8" will fit with guard rolling, 9" will also fit, but guards will need to be pulled and rolled. (this is assuming you are lowered)
NA8 rims are 14x6 +45
Those watanabes will fit, just depends on the amount of width and offset, will determine the amount of work needed to fit. Either rolling, plastic trimmings removed, pulling, amount of camber etc
16bit
Vehicle: NB8A - Supercharged
Rims
Postby 16bit » Wed Apr 15, 2009 4:29 pm
i think they are 185/60. however I have 205 50 15's on my 8's and they fit perfect. they are toyo r1r's and are apparently a 'wide' tyre. I have also heard that the bf goodrich sports are pretty wide too - and good value. you will not need 225's to fit on 8's - 9's on the other hand you would. have a look on clubroadster. they have heaps and heaps of info on wheel and tyre fitment and what needs to be done to make what fit.
philz
Wheel guru
Rims
Postby philz » Wed Apr 15, 2009 4:36 pm
LotusMX5 wrote:I'm thinking 8" rims need a 225 tyre and that sounds pretty big for an MX5. I'm guessing if it's over tyred a lot of the handling finese will be lost. Anyone care to comment on how wide can can go with the tyre before you start compromising the handling feel. I love the look of these rims, but I'd be concerned about going too wide for the sake of looks.
Tough looks versus performance..... :?
Edit, knowing now the orignal rim offsets, there is no way these rims will fit. Their offsets are 0 to -19 and we need roughly +35 on a 7" rim. The F8 type will fit but it aint got the dish and is not quite as cool.....but they fit.
What are the OEM tyre sizes?
With low offset = dish, you won't get it with +35 and especially on a 7" rim.
15x8 +0 offset, run 195/50/r15, guard rolling and camber.
Or use 14x8 instead.
OR alternatively get flares.
Images:
Sensible offset and can still look good and be tracked, but does not have alot of dish.
OR more dish, but requires flares.
philz
Wheel guru
Rims
Postby philz » Wed Apr 15, 2009 5:25 pm
Not my car unfortunately.
What size 14 or 15?
IMO 14x6.5+14.5 will look good, shown below.
PUR157
Rims
Postby PUR157 » Wed Apr 15, 2009 10:16 pm
Confirming - NA8 OEM Tyres are 185/60R14
Oneness of Man and Machine
Rims
Postby Jeo » Wed Apr 15, 2009 10:33 pm
philz wrote:With low offset = dish, you won't get it with +35 and especially on a 7" rim.
So what does that do to performance/handling then?
rjastra2
Rims
Postby rjastra2 » Thu Apr 16, 2009 4:38 pm
8 inch wide rims on a NA are illegal aren't they? And widening the track too much with incorrect offset wheels is as well?
