Get Rigid... MX-5 Suspension Braces
Posted: Mon Apr 06, 2009 11:54 pm
Hi,
I bought my first MX-5 a few months ago. A 1999 Twilight Blue NB, completely stock with low klms and an engine bay you could eat out of...
I have been on a steep learning curve since then as the handling was nowhere near the "riding on rails" experience that so many describe the MX-5 by.
Symptoms - Amazing and secure in a straight line on smooth, flat road with very little to complain about. Cornering to any degree was like steering a boat. On any kind of corrugated surface ( ie most NSW roads ) shuddering, oversteer, very nervous in the rear when cornering and even more so when braking in a corner.
Three different suspension and tyre places checked the car on the hoist and reported that all suspension components where perfectly fine and couldn't figure out why the car behaved like it did.
Endless nights of Google and scouring through forums around the world led me to believe that it was all due to chassis flex. The chassis had become a giant flexing shock absorber along with the driver and passenger.
So, after changing the tyres to Bridgestone Adrenalins (brilliant), bracing the chassis began with the obligatory front tower strut brace. This reduced the oversteer immediately.
I decided to go with a local manufacturer called Ultra Racing who make a full set of braces for the NA. With a slight bit of tweaking they fit the NB and the results are very impressive. http://www.ultraracingaustralia.com/page15.htm
After driving with the upper brace and new tyres for a week or so, I took the NB back to SuziTech http://www.suzitech.com/
to fit the front lower brace
and the lower middle brace
I could feel the difference as I backed the car out of the workshop! Now the MX-5 lives up to it's reputation of precise handling and driver pleasure. The car has it's original shocks, springs and bushes, but suddenly feels stiffer and far more solid. I can feel the suspension working as I drive.
Peter at SuziTech described bracing the chassis to be like laminating timber. A thick piece of timber can flex and eventually warp, but layers of thinner, laminated timber are much stronger and resist greater degrees of flex. I have since added a Style II Stylebar mounted across the seatbelt towers to strengthen the upper middle and relieve some of the shudder in the body and open roof.
I plan to continue onto the rear with a lower control arm brace from Racing Beat that I have on the way from the USA and possibly a rear strut tower brace in the boot.
Just thought I would share the love...
