I have coilovers...
Do I move the spring perch (the purple collar in the pic) up or down to RAISE UP the car.
Need to raise up the car heaps to get it up on ramps.
Thanks in advance sorry for the nube question.
Nube question how do I RAISE UP my car?
every ounce counts
Up
p.s, can you drive the car up onto a block of wood or a paver or something to get another inch in height? easier than raising the suspension....
- marcusus
Just take the collar off. Saves weight
I'm surprised you painted your calipers. I thought that'd add weight as well.
My trolley jack doesn't fit under the car, so what I do is use the scissor jack to lift it a bit, then wheel the trolley jack in and go from there. Sure beats raising the suspension each time.
- Jeo
marcusus wrote:I'm surprised you painted your calipers. I thought that'd add weight as well.
I was thinking the exact same thing
marcusus wrote:My trolley jack doesn't fit under the car, so what I do is use the scissor jack to lift it a bit, then wheel the trolley jack in and go from there. Sure beats raising the suspension each time.
If someone else is around I just get them to lift the car up a little. There's enough play in my suspension to then get my smaller trolley jack under it.
- de Bounce
I made a pair of low ramps which raises the front up so the jack fits under
Used some wood and about 1/2 hour
Users browsing this forum: No registered users and 177 guests
