I am getting a clunking sound from my front suspension, most often as i turn the wheel full lock to exit my carport, again when i brake to ease down the curb and sometimes when i stop at the lights.
This didn't start till just after grump and i fitted the braces we made up.
I am hoping it is just shot bushings giving the control arms room to moving in... not that this is a good thing but... could it be anything else major?
cheers
MB
Clunking from front suspension
- madboy
- Locutus
mine used to clunk when coming to a stop at the lights. turned out to be a loose lower control arm bolt.
previous alignment was performed by mob very highly regarded on this forum.
- Daz
Locutus wrote:mine used to clunk when coming to a stop at the lights. turned out to be a loose lower control arm bolt.
Same experience for me, got some dodgy alignment done and my next service found a loose bolt in the front... symptom was a loud clunk under hard cornering.
Take it to someone that knows the front end of an MX5 and have them check it.
Silver SP - PSS9, 1:10:58
- madboy
I'll take it back to the guys who did my alignment then, see what they can find
cheers
cheers
i had the same noise. i just got under there and tightened up everything that i could, mainly the control arm bolts ( LCA bolts worked their way a little bit loose after i replaced it) and it's fine now.
mine has started doing this since i slammed my car, however i have read that the endlinks tend to flex once your at my height and causes noises like this ... i still need to get some adjustable endlinks to avoid unwanted preload.
On mine, it was a lower ball joint.
Users browsing this forum: No registered users and 241 guests
