New alignment for different wheels??
wun911
Postby wun911 » Fri Feb 20, 2009 10:50 am
When you put on larger rims with wider rubber on a stock car do you have to get a new alignment?
Technically I have raised the height of the car due to the slighly larger wheel, so am I now riding with less camber??
Does a wider tread give you more or less toe in etc?
every ounce counts
Juffa
Postby Juffa » Fri Feb 20, 2009 11:24 am
While I cannot answer your questions re camber/ride height... I would suggest you should get a wheel alignment.
J
Postby hks_kansei » Fri Feb 20, 2009 12:02 pm
I would just leave it, wheels wont change it much.
if you're due for an alignment soon anyway, just wait.
however this is from a person who got bigger wheels and their car lowered without getting an alignment done :P
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Feb 20, 2009 4:11 pm
as long as your rolling diameter does not change it will not matter re the wheels. But lowering the car will change your alignment settings - sometimes quite a bit.
StanTheMan
Postby StanTheMan » Fri Feb 20, 2009 4:53 pm
larger wheels & tyre comination will not change the camber but will give you slightly wider track on the same allignment & same offset. but its prolly hardly worth a mention.
I'd be getting an allignment with new tyres regardless
project.r.racing
Postby project.r.racing » Fri Feb 20, 2009 8:29 pm
nothing changes too much, as others have posted.
recommend wheel alignment asap.
