LCA changeover. as simple as it looks?
Jace
Postby Jace » Sat Feb 07, 2009 12:19 am
my car got a booboo. only took a quick look when i was swapping to space saver (smaller rolling diameter, got me home!) but it looks very straightforward.
i'm talking right hand side front lower control arm.
shed some proverbial light? i guess i've got the things i need: trolley jack, socket wrench, sockets and time.
please help!
Jace
Postby Jace » Sat Feb 07, 2009 12:20 am
oh, pictures would also help a lot more than words. yeah, i'm one of those kinda guys.
Postby Okibi » Sat Feb 07, 2009 2:50 am
As long as the bolts aren't seized it should be easy enough.
philz
Wheel guru
Postby philz » Sat Feb 07, 2009 10:47 am
Easy, it's just nuts and bolts.
but as okibi said, if it's not seized it will be fine.
If the long bolt is bent, you'll be happily be banging it out for a good 1-2hrs.
Oh and wd40 plus a hammer is your friend.
And a breaker bar for the tighter bolts.
Jace
Postby Jace » Sat Feb 07, 2009 11:48 am
thanks guys.
Postby Okibi » Sat Feb 07, 2009 12:22 pm
Last week I had an upper arm bolt that just didn't want to move, I thought it was going to snap the breaker bar, just be patient, pray a little and swear a lot.
philz
Wheel guru
Postby philz » Sat Feb 07, 2009 1:17 pm
Just for show, this is what I had to go through, long bolt on the lower control arm- rear.
Banging with a 3 pound sledge hammer, 1/4 can of wd40, and twisting the bolt out with a 40cm breaker bar.
Jace
Postby Jace » Sat Feb 07, 2009 9:17 pm
well, that sucks. sounds like i got off reasonably easy.
did find that i bent the sway bar linkage and shock absorber a fair bit, as well as blowing out the shocker.
so i now need a linkage, the little (100mm long) connector with perpendicular bolt hole with bushes on either end.
anyone wanna mail me one to save me a drive back to melbourne? pm me please!
whoa_dang_96
Postby whoa_dang_96 » Mon Feb 23, 2009 3:11 pm
come on guys - step into the 21st century and use a rattle gun - you can do HEAPS more damage :lol:
CT
Postby CT » Mon Feb 23, 2009 5:46 pm
You were lucky! I've had to cut one in half with a dremel, melt the bushes with a burner and they still didn't want to come out. Took about 4hrs that day.....what a PITA!
grump
Postby grump » Mon Feb 23, 2009 6:15 pm
pm Tbro, he just did bushes on scooter one night last week. It also helps that he is a mechanic.
Users browsing this forum: Bing [Bot] and 235 guests
