Scuttle Shake - Best bang for buck NA6a ?
Posted: Thu Jan 29, 2009 10:26 am
by kazjim
G'day guys, well I've had my 5 for a few months now, so its probably time to start tinkering
its a totally stock 89 Na6a, and driving on any road with more than a hint of a bump ends in lots of shaking (I'm assuming this is scuttle shake!)
I know there are lots of fixes, shock tower braces, underbody braces, roll cages etc etc.. but which gives a good result for the best money ?
I'd rather not have a cage, i like the totally open cabin feel of the stock 5 ....
Quite handy, so can do just about anything myself .... save a few bucks on fitting anyway
Cheers Guys
J
Posted: Thu Jan 29, 2009 10:30 am
by philz
I would say underbody brace- flying miata butterfly brace
Posted: Thu Jan 29, 2009 12:27 pm
by StanTheMan
^^^and a full wheel allignment & ballance just to be sure
Posted: Thu Jan 29, 2009 4:31 pm
by grump
well the best I have felt is the difference to graemebc's na8 after fitting the mx5plus torque tube roll bar last saturday. you wouldn't think it was the same car.
Posted: Thu Jan 29, 2009 5:02 pm
by Steampunk
apparently these, according to
Boss Frog at least
Posted: Thu Jan 29, 2009 5:04 pm
by StanTheMan
good chance if its an early NA6 both lower chasis braces are not there. They were satndard on the NA8
http://www.mx5mania.com.au/product649.htmcheck if you have them fitted. If you don't fit them both. Then you also need to make sure the wheels are ballanced & aligned.
however as mentioned before the flying miata under body brace will sort it for sure. but its exxy....
Posted: Thu Jan 29, 2009 10:56 pm
by graemebc
I have braces coming out the wazooo ( yes its painful)
the best thing I have fitted and the thing that almost totally eliminated the shake was the torque box roll over bar from mx5plus. 2 hours to fit ( even with grump acting the goose)
unobtrusive as far as bars go, if you can call a bar with cross brace behind you head unobtrusive
by far and away the best money I have spent on the car. I can not stress enough how much better the car is to drive. Its transformed it. It no longer "rattles' over bumps its absorbs them, even with Teins on. Honestly its so much better its hard to believe.
You need to add bracing at the points of max flex to stop torsional twisting, that is under the car along the rails & between the front pillars and behind your head between the uprights. So two choices bar or frame rails
I would like the boss fig braces too but even those guys and emelio at 949 racing have said they do more to help turn in than stop alot of flex, Still every bit helps hey
Posted: Fri Jan 30, 2009 10:46 am
by kazjim
Thanks guys, the Flyin Miata braces look the goods, but i really cant justify that amount of $$$ !!!
I think I'll start off with the Mania chassis braces and see what that feels like, then maybe add an N8 seat-belt tower brace (Had a ride in LVD60'S n8 last night and it felt a lot stiffer than my N6 . . .)
thanks all
J
Posted: Fri Jan 30, 2009 11:05 am
by Fatty
kazjim wrote:I think I'll start off with the Mania chassis braces and see what that feels like, then maybe add an N8 seat-belt tower brace (Had a ride in LVD60'S n8 last night and it felt a lot stiffer than my N6 . . .)
that's exactly what i would do, that should get you a very good improvement, for minimal outlay.
Posted: Fri Jan 30, 2009 11:26 am
by ampz
a little bit of bent tube and you have your own underbody chassis braces, if you're handy ;)
Posted: Tue Feb 10, 2009 8:55 am
by Moto
1red5 wrote:apparently these, according to
Boss Frog at least
lol @ the 'Straight Cat'
"The Boss Frog "Straight Cat" is a great alternative to knocking the center out of your stock catalytic converter, or buying an expensive high-flow model."
\off topic
Posted: Wed Feb 11, 2009 5:18 pm
by Cent
You know you love flames!
Posted: Thu Feb 12, 2009 7:50 am
by graemebc
flames =
but not in the long term if your like your valves
Posted: Thu Feb 19, 2009 9:01 am
by Muzdaman
kazjim wrote:Thanks guys, the Flyin Miata braces look the goods, but i really cant justify that amount of $$$ !!!
thanks all
J
I have the Mania braces and the NA8 seat belt brace and it stiffened things up nicely.
Posted: Wed Mar 25, 2009 7:43 pm
by Steampunk
OH!
Actually....!
I completely forgot about my rear upper strut-tower brace (Beatrush).
This was my last suspension/chassis mod and I was pleasantly surprised it made a tangible difference (cause I didn't expect any, and bought it more for the *bling*), even after installing a front strut-brace, big anti-sway bars, and MX-5Plus Torque Box Roll Bar.
Forgot what I paid for it, but I wouldn't have bought it if it was exhorbitant.
