Scuttle Shake - Best bang for buck NA6a ?
kazjim
Postby kazjim » Thu Jan 29, 2009 10:26 am
G'day guys, well I've had my 5 for a few months now, so its probably time to start tinkering :D
its a totally stock 89 Na6a, and driving on any road with more than a hint of a bump ends in lots of shaking (I'm assuming this is scuttle shake!)
I know there are lots of fixes, shock tower braces, underbody braces, roll cages etc etc.. but which gives a good result for the best money ?
I'd rather not have a cage, i like the totally open cabin feel of the stock 5 ....
Quite handy, so can do just about anything myself .... save a few bucks on fitting anyway 8)
Cheers Guys
J
If my calculations are correct, when this baby hits eighty-eight miles per hour ... you're gonna see some serious s**t.
philz
Wheel guru
Postby philz » Thu Jan 29, 2009 10:30 am
I would say underbody brace- flying miata butterfly brace
StanTheMan
Postby StanTheMan » Thu Jan 29, 2009 12:27 pm
^^^and a full wheel allignment & ballance just to be sure
grump
Postby grump » Thu Jan 29, 2009 4:31 pm
well the best I have felt is the difference to graemebc's na8 after fitting the mx5plus torque tube roll bar last saturday. you wouldn't think it was the same car.
Steampunk
Postby Steampunk » Thu Jan 29, 2009 5:02 pm
apparently these, according to Boss Frog at least
StanTheMan
Postby StanTheMan » Thu Jan 29, 2009 5:04 pm
good chance if its an early NA6 both lower chasis braces are not there. They were satndard on the NA8
http://www.mx5mania.com.au/product649.htm
check if you have them fitted. If you don't fit them both. Then you also need to make sure the wheels are ballanced & aligned.
however as mentioned before the flying miata under body brace will sort it for sure. but its exxy....
kazjim
Postby kazjim » Fri Jan 30, 2009 10:46 am
Thanks guys, the Flyin Miata braces look the goods, but i really cant justify that amount of $$$ !!!
I think I'll start off with the Mania chassis braces and see what that feels like, then maybe add an N8 seat-belt tower brace (Had a ride in LVD60'S n8 last night and it felt a lot stiffer than my N6 . . .)
thanks all :lol:
J
Fatty
Postby Fatty » Fri Jan 30, 2009 11:05 am
kazjim wrote:I think I'll start off with the Mania chassis braces and see what that feels like, then maybe add an N8 seat-belt tower brace (Had a ride in LVD60'S n8 last night and it felt a lot stiffer than my N6 . . .)
that's exactly what i would do, that should get you a very good improvement, for minimal outlay.
ampz
Postby ampz » Fri Jan 30, 2009 11:26 am
a little bit of bent tube and you have your own underbody chassis braces, if you're handy ;)
Huh?
Moto
Postby Moto » Tue Feb 10, 2009 8:55 am
1red5 wrote:apparently these, according to Boss Frog at least
lol @ the 'Straight Cat'
"The Boss Frog "Straight Cat" is a great alternative to knocking the center out of your stock catalytic converter, or buying an expensive high-flow model."
\off topic
Cent
Postby Cent » Wed Feb 11, 2009 5:18 pm
You know you love flames!
NB8B
Muzdaman
Postby Muzdaman » Thu Feb 19, 2009 9:01 am
kazjim wrote:Thanks guys, the Flyin Miata braces look the goods, but i really cant justify that amount of $$$ !!!
thanks all :lol:
J
I have the Mania braces and the NA8 seat belt brace and it stiffened things up nicely.
Steampunk
Postby Steampunk » Wed Mar 25, 2009 7:43 pm
OH!
Actually....!
I completely forgot about my rear upper strut-tower brace (Beatrush).
This was my last suspension/chassis mod and I was pleasantly surprised it made a tangible difference (cause I didn't expect any, and bought it more for the *bling*), even after installing a front strut-brace, big anti-sway bars, and MX-5Plus Torque Box Roll Bar.
Forgot what I paid for it, but I wouldn't have bought it if it was exhorbitant.
