Max size of wheels
Max size of wheels
Hey guys,
I have an opportunity but buy a set of wheels 19x7.5 +42 with 215 30 19 rubbers, will they fit an NA std hight...
Please do not mention that the speedo will change and the ride will be harsher and so on... I like the look but cant test fit as they are in Syd and I am in Melb.
please advise if they will fit..
Total hight 633mm
Total hight 633mm
Max size of wheels
DEAR GOD DO NOT DO IT!
MX-5's arent made to be "hektic omg ulleh" cars, also known as "sexspec"
however due to the lame offset, they would fit, but my god it would looks so fricken stupid, you will regret doing it! As you wont be able to go very low either. It would make 4WD's look low.
biggest size you would go on an NA without the rims looking too big for the car would be 17's.
Max size of wheels
pfffffffffft mxhevn, you don't know what you're talkin about.
it'll look grouse mate!
- Jeo
Max size of wheels
I'd imagine it could be made to fit, but whether it would fit under stock guards may get you a different answer.
JST402 had 18's on his NB and they looked like there wasn't much room to spare. Not sure if he modified his guards though.
I'm not a fan of that look myself, and I wouldn't put 19's on my NA but at the end of the day it’s your car. If you like the look, then go for it.
I'd suggest having a look around on some of the bigger US forums to see if you can find any pictures of NA's with 19's. Make sure you do actually like the look before you commit.
- Boags
Max size of wheels
Get your flame suit on; you're going to get burned.
Max size of wheels
Jeo wrote:I'd suggest having a look around on some of the bigger US forums to see if you can find any pictures of NA's with 19's. Make sure you do actually like the look before you commit.
i highly suggest you do not do this, as majority of the yanks run 14's 15's and 16's. If you do however look around and manage to make a post, i would LOVE to see the outcome of the thread
- philz
- Wheel guru
Max size of wheels
NO car should be made to "hektic omg ulleh" cars.
19 is pushing it, 18's will fit.
Personally I wouldn't go more than 16" each to their own though.
- 16bit
Max size of wheels
this is a terrible idea - they will look worse than they will perform. not to mention they proably just won't fit no matter what you do.
Max size of wheels
16bit wrote:this is a terrible idea - they will look worse than they will perform.
actually , i think they will perform worse than they look. altho how they "look" is subjective, i guess.
but yeah, say goodbye to your sportscar handling, and say hello to 4WD like handling.
- HIC-45S
Max size of wheels
To the letter of the law, there is no rule saying that the diameter of your rims must be a certain maximum size above standard, providing the rolling diameter is not changed more than 15mm, the rim width doesn't go any narrower or 25mm wider, it stays in the bodywork without fouling on suspension, spacers aren't used and the wheel track does get 25mm wider. Otherwise you need to get an engineer's certificate to make it all legal.
Now while I won't stop you, I wouldn't put 19" wheels onto my Skyline as I like a little bit of tyre wall on my tyres lol
スカイライン ECR33 GTS25-t SII
"We produced with Spartan air"
- Jeo
Max size of wheels
MXHEVN wrote:Jeo wrote:I'd suggest having a look around on some of the bigger US forums to see if you can find any pictures of NA's with 19's. Make sure you do actually like the look before you commit.
No you're dead right there, I wouldn't suggest you first post on one of the bigger forums as "I want to run 19's". Those Yanky types aren't as nice as we are
But I'm still sticking with my "look around and see if you can't find someone else that already has 19's" theory. Someone, somewhere has to have already done it haven't they?
Once you've seen how it sits, you'll be better informed as to whether you do want to go that way.
Max size of wheels
Ahhhh.... thank you all... you have reminded me why I left this forum last time...
Why do some of you find it so hard to understand some people's tastes are different to yours, I like the look of a small car with large diameter wheels and low profile tires. And as usual I asked a simple question and the topic has turned into a flaming session.
If you cannot answer the question or add value to the topic then dont contribute to mine... PLEASE...
And for those who laughed at the size... take a tape measure and measure your little ones (wheels)
205/50/16 = 612mm height
225/50/16 = 631mm height
215/45/17 = 626mm height
215/35/19 = 633mm height
And I can safely assume people would not say my car would look like a 4x4 if I chose 205/50/16. The interesting thing is if I ran the 19's the car will ONLY sit 1cm higher. Oh but wait I have height adjustable coilovers and can compensate for the rise and WOW the car sits at the same height as a 16" .
This is not a race car so I don’t car about gearing, the rolling centre is marginally increased which would not be noticeable on the street, they weigh under 9kg each so weight is not an issue either.
So PLEASE I would love to hear your opinions and advice if I can FIT the 19" in the guards and turn the steering wheel without fouling against the body.
I apologise to those who tried to help.
Max size of wheels
i think most people that have replied to your thread have helped in someway.
what i dont understand is why you want 19's on a car made for handiling, i'm guessing you have not experienced the joy of going through a bunch of twisties with a smile on your face? i am also guessing you are one of those George ST warriors that like to show of their bling!
if you like small cars with big rims, get a charade or some other trolley that handles like sh*t.
Max size of wheels
Jeo wrote:MXHEVN wrote:Jeo wrote:But I'm still sticking with my "look around and see if you can't find someone else that already has 19's" theory. Someone, somewhere has to have already done it haven't they?
i sure hope not.
- StanTheMan
Max size of wheels
well since you brought up the size
standard size for an NB8B/C is actually
205/45x16= 590.80
standard size for an NA6/8
185/60x14= 577.59
Standard size for NB8A
195/50x15= 575.81
since were measuring willies....errr wheels
those are the standard sizes.
apart from that
with standard height which you mentioned in the original post I'd say they'd fit
you're obviously not concerned about legalities.......
205/45x16= 590.80
185/60x14= 577.59
195/50x15= 575.81
apart from that
