Allen key size for rear brake adjustment
i seem to have misplaced my metric allen key set, and my haynes manual doesn't list the size i need. to save me buying the wrong item, can someone tell me what size allen key i need to for the rear brake adjustment on the na8/nb8a brakes? cheers
The enthusiasts guide says 6mm. But that didn't sound right...so I just went out to the garage, pulled out my old set of NA6 brakes...... I'm almost 100% sure that the same sized key is required for the NA6 and the NA8/NB8A/B.
The answer is 4mm.
J
The answer is 4mm.
J
thanks mate, you're a champ.
- Garry
4mm on NB8B. I fitted my new brakes last Tuesday.
Duuuuuuude, buy an entire set of allen keys, cheap as chips (you don't need fancy ones for the brakes).
There's so many things you'll end up using them on. I think I used 3 different sized allen keys doing an oil change on my motorbike.
I also only buy the tools I need...
I also only buy the sockets I need...
(Yeah I did mine just now its size 4)
every ounce counts
- PUR157
wun911 wrote:I also only buy the tools I need...
Is this to save weight in your toolbox?
Oneness of Man and Machine
Users browsing this forum: No registered users and 149 guests
