hey guys just wondering where to get a wheel alignment in brisbane. I have my own specs as per below. please comment if I am going down the wrong track. this is taking chalie browns comments into account.
The Car:
Ride height - max low on tien ss coil overs with stock spring rates of 5/4 i think.
Wheels - 15 x 8 with 0 offset with 205/50/15 toyo r1r's
Whiteline front sway bar on soft with stock rear bar
Aligment specs
Front:
Caster: Max
Camber: Max
Toe in: 2mm total - 1mm per side
Rear:
Caster: NA
Camber: max
Toe in: 2.5mm total - 1.25mm per side
wheel aligment in brisbane
- 16bit
I went exactly the same, except only 1mm toe (total) on the front.
Car still doesn't tramline and handles fantastically! Slight oversteer in lower speed corners (mainly due to a heavy right foot ) but very stable at higher speeds and best of all, no understeer!
The emotion of motion... Zoom-Zoom!
- rwf
- Vehicle: NB Roadster
Fulcrum is the place to go just had the nc in there to get tein springs fitted and alignment feels great on road see how it is on the track Friday
Yep what RWF said,
Had mine done Thursday morn before going out to track,
max camber front and rear, max castor,2mm front 1.5mm rear.
Made up nearly 1.5seconds with track wet through dip.
Book in with Simon at Yeerongpilly.
I don't ask for anything special but the aligner set to suit a trackday.
Terry
Terry
- 16bit
so you had more toe on the front then rear? what would this do?
Users browsing this forum: No registered users and 184 guests
