Page 1 of 2
Wheel nuts
Posted: Mon Dec 01, 2008 5:48 pm
by Fuzzlet
Whilst doing a test fit of my track rims I ran into a problem - my wheel brace is too large if I want to use the SE's original wheel nuts. The nuts fit ok, its just the hole on the rim isnt big enough to fit the brace. Anyone know of a decent brand etc that are smaller than the standard nuts?
Wheel nuts
Posted: Mon Dec 01, 2008 6:09 pm
by grump
Fuzzlet, I have found a long breaking bar and a longreach socket do the job. I don't think you will get a thinner wall thickness than a good quality socket.
Wheel nuts
Posted: Mon Dec 01, 2008 8:42 pm
by d-mag
Same thing happened to me on a previous car, I pulled up to a Super Cheap grabbed a few braces, took them out and test fit them all 'till I found one that fit.
Wheel nuts
Posted: Mon Dec 01, 2008 10:06 pm
by bigdog
I use internal hex wheel nuts with a 12mm hex half inch drive socket (not the key that comes with the nuts). No chance of scratching the wheels this way :D
Wheel nuts
Posted: Mon Dec 01, 2008 10:54 pm
by wun911
I file mine down so it could take a smaller socket...
Wheel nuts
Posted: Tue Dec 02, 2008 12:01 am
by Fuzzlet
Well after chatting with the previous owner of wheels he said he ran 17mm lightweight nuts, and apparently with a 19mm socket he could use standard nuts. The SE's are bigger than this, so looks like a second set of nuts are in order....will mean I can get some lightweight ones :P
As for scratching the wheels - not really a problem, since the (green...) paint is already chipping off, and I'm planning on sandblasting them when these tyres wear out
Wheel nuts
Posted: Tue Dec 02, 2008 5:10 pm
by Fuzzlet
Well I have ordered some new (lightweight) wheel nuts. Should be here within a few days thankfully
Wheel nuts
Posted: Tue Mar 31, 2009 1:07 am
by TieNN89
what did you get?
any pics?
Wheel nuts
Posted: Tue Mar 31, 2009 2:12 am
by Fuzzlet
Buddyclub lightweight nuts. Not cheap, not lighter than stock nuts (infact weigh almost double), however they do fit with these rims
Wheel nuts
Posted: Tue Mar 31, 2009 11:09 pm
by TieNN89
Fuzzlet wrote:Buddyclub lightweight nuts. Not cheap, not lighter than stock nuts (infact weigh almost double), however they do fit with these rims
ha misleading then
lightweight nuts that weight double stock nuts
Wheel nuts
Posted: Tue Mar 31, 2009 11:29 pm
by Fuzzlet
Yea if these are the 'lightweight' nuts I'd hate to see the 'standard' ones then. Having said that these ones are around 50mm long, meaning they fit down the 20mm cutouts for the wheel nuts and I can fit a 17mm socket over them to do them up
Wheel nuts
Posted: Wed Apr 01, 2009 1:50 pm
by wun911
I would be deeply cut thats very deceptive; like saying 'superlite wheels' that are 7 kg each.
There should be a law against such false claims in advertising.
I would consider any nut under 25 grams to be considered as 'lighweight'.
Wheel nuts
Posted: Wed Apr 01, 2009 11:17 pm
by TieNN89
any idea what the weight for the stock ones are?
Wheel nuts
Posted: Thu Apr 02, 2009 10:13 pm
by TieNN89
33gram are my stock ones
Wheel nuts
Posted: Fri Apr 03, 2009 1:57 pm
by hks_kansei
will lightweight nuts make ANY difference that is noticable?
the difference overall between a 33g nut and a 70g nut is 592g for the whole car, or 148g per wheel.
148g right in the centre on the wheel is likely to make ƒü¢k all difference!
you can save about the same amount of weight by skipping lunch!
ok, finished ranting.
I'll show myself the door to this thread.
