Rattling brake pads
Gazbo
Rattling brake pads
Postby Gazbo » Thu Nov 13, 2008 9:49 pm
I know it's the brake pads because even a slight application of the brake pedal and the rattling stops.
I've fitted new anti-rattle clips and springs, applied that CRC orange goop behind the shims, and fitted new (Bendix GCT) pads, and still the brakes rattle incessantly.
What's the solution?
Daily: 2006 "C" Mazda3 SP23
Fun: 1993 NA6
tbro
Rattling brake pads
Postby tbro » Fri Nov 14, 2008 7:52 pm
Gazbo wrote:I know it's the brake pads because even a slight application of the brake pedal and the rattling stops.
Hey Gazbo,
When you say you fitted new clips and springs do you mean the w springs and the clips for the end of the pads.
If so the only cause I can think of,all being equal is, when you fitted the clips the spring tab has bent down loosing tension, the easiest way to correct this is remove pads again and slightly bend the spring tensioner up a bit and refit pads. After fitting pads you should just be able to move pad up and down by the smallest margin. If the clips are ok again slightly expand the W springs out to increase tension.
I've seen many mechanics have problems fitting these clips as at times they can be a bastard to get everything sliding into place just right.
As for the CRC goop I'm not a bit fan of this stuff as it was really developed to cover up poor caliper designs from the 70s by Bendix, re flexing alloy units.
Hope this helps, as from experence I know how bloody annoying brake rattles can be. :lol: :lol:
Terry
Tedsmx5
Vehicle: NA8 - Supercharged
Rattling brake pads
Postby Tedsmx5 » Fri Nov 14, 2008 8:07 pm
Gasbo,
If it's the rear brakes they may need to be adjusted. My adjustors were stripped and required a rebuild, I also removed the thin backing plates (the mazda ones) and used that goop on the back of the pad (mine was blue obviously superior :lol: ) no more rattles. The springs suck!!!
Ted
Why didn't I buy one years ago?
NA8 Ceramic coated headers, Hi flow cat, 2.5”system, M45 SC 150/62.5 8psi, Dual TB, IC & Adaptronic ECU.
Gazbo
Rattling brake pads
Postby Gazbo » Fri Nov 14, 2008 10:11 pm
Terry, yes, I did buy both new clips and the "w" springs.
I've tried stretching the "w" springs out a little more, but didn't touch the clips, I'll try bending the spring tabs out a little more as you suggest.
Ted, I never considered the rear pads could be the source of the rattling, have to check the adjustment of those.
Thanks guys!
Gazbo
Rattling brake pads
Postby Gazbo » Sat Nov 15, 2008 4:19 pm
Changed the brake fluid, greased the calipers, and adjusted the rear brakes correctly.
Rattles mostly gone, just the occasional noise over a big bump. :)
Users browsing this forum: No registered users and 160 guests
