rear suspension related squeak.
All of a sudden i have noticed a squeak which is evident when the suspension flexes. It sounds like its coming from the right side and it is reeeeeeeeeallly annoying. Could it be a stressed bush? anyone had this problem?
wow, i do believe i have the same thing goin on. im putting it down to a bit of an incident with a kerb
after my service on tuesday the mechanic said its most likely the right shocky, once i can be bothered ill start looking for a cheap stocko one n see if that fixes it
Well i havent actually hit anything, yet.. So it just appeared out of no where, my mechanic had a look, sprayed some silicone in places but said he cant really get to it unless he puts it up on the hoyst, however he was too busy.
Im maybe putting it down to coilovers so ill be sure to let you know if things change when i install my new springs.
I hope its not a shocko : I have two front shockers spare, however i dont know what model they are for nor do i know if they are any good.
Users browsing this forum: No registered users and 171 guests
