Anyone tried the OptionsAustralia MX5 Coilover Kit on ebay?
- Scoota
Hi Folks.
Has anyone out there tried this kit on ebay?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?viewItem&ssPageName=STRK:MEWAX:IT&item=370092496611
Alternatively, item # 370092496611
This seems ludicrously cheap for a lowering kit. They are very vague about the kit in the listing, and they haven't answered any of my questions, so I'm fishing for more details and maybe some feedback from someone that has tried this kit. I'm not about to rush into it, but I am tempted.
Trav.
Trav.
- philz
- Wheel guru
Those are sleeves. Stay away.
Either stick with replacement springs, spring & shock combo or Coilovers.
- Scoota
I'm confused. Why are sleeves no good? They are basically an adjustable lower spring perch, aren't they? My Koni's have an adjustable lower spring - three slots for the circlip. Surely an infinitely adjustable threaded sleeve would be a more flexible arrangement in terms of tuning potential.
... or am I missing something??
- philz
- Wheel guru
Read:
Ground Control, the pioneer in sleeve design technology' utilizes aluminum body sleeve with Eibach race springs. The base of the spring is supported with a single rotational plate with an Allen screw-locking device. What's wrong with this design you ask?
Like all 'sleeve type' coilovers, there is good chance for the sleeve to rotate and thus make the spring slip. This can happen to the enthusiast drivers who like to push the car to the limit. The other thing that worries me is the Allen screw-locking device. A screw that small is given the duties to hold the tension and twist that are generated by the car when an enthusiast drives it.
- Steampunk
If you think that is cheap, go to eBay US/eBay Motors and see how much they are flogging them off over there for.
I would also question the spring rate. I won't be surprised if the springs are as soft as bed springs.
One word: Dodgy
One word: Dodgy
- Scoota
Yeah, I agree 1red5, I won't get these until I know what the spring rates are. And I also agree that these are definitely cheap and dodgy, but that doesn't mean they can't be made to work well.
I understand that if the sleeve is not securely anchored to the damper body then it could spin, which would be bad. But I reckon it wouldn't be too hard to get it anchored securely.
Are there any other potential issues that I should know about?
- Mactype
philz wrote:Read:
So I'm presuming you have empirical data to back up this sweeping statement?
I'm running a Ground Control/Eibach/Koni Race setup and the car sees a bit of track time. I can see, nor have had any problem with the setup. Their actually a very well made piece of kit.
I'd be more concerned over what valving, spring rate and open and closed lengths of a custom shock setup are. and then what sort of adjustability you have.
Lotus Exige
- philz
- Wheel guru
This was taken from a site, obviously there will be some people for and against.
I havn't never heard many good things from Coilover sleeves.
However I have heard a fair few miata owners using ground control sleeves.
But the OP asked about those Ebay coilover sleeves which I say stay away.
- Mactype
philz wrote:This was taken from a site, obviously there will be some people for and against.
So from this we can take your posts as cut and past opinions with no real evidence to back up your claims
Lotus Exige
- meanmx
From what my little research has shown up these springs are apparently incredibly harsh. The ground controls on the other hand I've heard nothing but good things about. If you really want this type of setup then I would go the extra with ground control. And yes they are alot cheaper in the US of A but the shipping kills it
Ben
Ben
2014 VW Mk7 Golf R
- Steampunk
meanmx wrote:And yes they are alot cheaper in the US of A but the shipping kills it
Ben
That's not what I meant about being cheaper, I'm alluding to the good ol' saying "you get what you pay for"
- Scoota
Hey, thanks for the feedback meanmx. Do you know someone that has tried these springs? What makes you say they are harsh?
Keep the comments coming folks. At this stage I am still considering these as a way to give me a way to corner-weight the car, but I won't be getting them if the spring rates aren't in the ball park. I still haven't got an answer from the seller, so I'm totally in the dark about details at the moment.
- Vehicle: 10AE - Turbo
I was just going to put a post up asking about these.... I wanted 2 for the front of my car. I have also emailed them asking about spring rates but not got an answer back yet. as far as securing them, the workshop I use can weld them onto the shock, they do it often with over brand ones.
I guess I will probably be the guinea pig in a couple of weeks...
MX5 13B - NFS Racing
PRO-MX5 PB 7.46 @ 179mph & 1.07 60ft
- meanmx
Scoota wrote:Hey, thanks for the feedback meanmx. Do you know someone that has tried these springs? What makes you say they are harsh?
At the time I was doing alot of research into a suspension setup and spent alot of time on miatanet and clubroadster. The threads were somewhere in there. I was pretty much after independant height control as well so I had a look at these as well as ground control but decided in the end to do it properly with a full adjustable coilover. The problem is that one person can say they are very harsh and another person can say they are only a little bit harsh and you don't know whose opinion to take but the general concensus with these is that they work but are very harsh. On top of that I was worried about longevity as well. They look great in the pics but there are a couple of different spring construction methods that are used with some being better than others. Also I took into account the fact that they may have skimped on the quality of the metal used (dad always says you get what you pay for). There were just no long term reports yet about how they hold up quality wise and with the lack of information they quickly got axed from my shortlist.
Ben
2014 VW Mk7 Golf R
They just got back to me and said the spring rate is 200kg....... is that good or bad....?
Users browsing this forum: Google [Bot] and 5 guests
