Hi, I'm due for a brake pad change. Stock set lasted almost 130,000 Km's
Where can i get the spring clips and W wire for the NB8B brake pads?
I looked at mx5parts UK but they don't have them for the NB8B "sport/big brakes"
I need to change them soon, one pad just hit the "squeak" indicator
I've been researching brake pads as well. So hard to decide. Any recommendation for street pads?
Has anyone ordered OEM pads with the spring/clips from overseas (if so where)?
NB8B Brake Pads
- Hellmun
- Vehicle: NB8B - Turbo
NB8B Brake Pads
Only place I know of. http://www.miatamania.com/Shop/ViewProducts.aspx?PlateIndexID=59051
- ducktape69
NB8B Brake Pads
i see different items for 'Sport Susp.' and 'Normal Suspension'.
i can see on the door sill sticker it says Sports suspension...whats the difference? rotor sizes?
- Hellmun
NB8B Brake Pads
270mm front rotors and 276mm rear rotors in the sport package. With different calipers to suit. You can tell if you have the sport package by whether your car was post 2001, 6 speed manual and came with 16" rims. All NB8B's came with the sport brakes in Australia. It was an option in the states.
NB8B Brake Pads
Hellmun wrote:Only place I know of. http://www.miatamania.com/Shop/ViewProducts.aspx?PlateIndexID=59051
Thanks
I assume the part below is for both front corners? There is no part listing for the rear
Part # 904-828
Price: $6.95
Description: 4. Clip Set, Pad Note: Brand - Mazda
Application: 01-05 Sport Susp.
- Hellmun
NB8B Brake Pads
There's actually 8 clips and a tube of silicon grease. Plus 2 extra small clips which I don't know what are for. I'd never opened one of the packets until now. I bought 2 sets a while ago but never ended up needing to change my clips. They might have made a typo on the rear brake page as they've got the rear pads for one year model listed twice with the same part number. You could try emailing them.
NB8B Brake Pads
Thanks. I will shoot them an email. I might no even need to change the clips. I just assumed it was required when changing pads. I do have one loose rear clip, but hardly noticeable.
Might get some Hawk HPS pads as well.
- Hellmun
NB8B Brake Pads
Yeah I know your supposed to but I'm on about....wow...my 6th set of front brake pads in about 25,000km's now I think about it (sumitomo's, DS2500's, Hawk HP+ and two sets of DS3000's with a new set arriving this week) . I still havn't needed to replace the clips... that's mostly trackday abuse as well.
NB8B Brake Pads
I have NB8B with the 270mm front rotor.
I changed my pads with the dealer at 100,000 km with the timing belt at garry warren smith.
They didnt give me new shims or clips!
Now 140,000 km the clips perished on the rear, started to rattle upon initial breaking and breaking on uneven road.
I got oem pads from mx5 parts uk came with all shims and clips. For clips per caliper fifth clip dont know where it go but can still stop without so its unsprung weight savings for me
NA** NB8A and NB8B clips not interchangeable I have tried simply does not fit they are too small. So only way to get clips is from mx5 parts uk, but have to buy the pad to get the clip.
You get shims aswell (goes on the back of the pad) but not need to stop just need for quiet, can get can of spray on break quiet so no need for shim, potential unsprung weight savings
Now 150,000 km I see oem from mx5 parts uk is less dusty than what ever aus mazda dealer gave me but still stop the same so all is good for daily driver.
Dont forget to grease caliper pins while you do it.
every ounce counts
- Vehicle: ND - 2
NB8B Brake Pads
Hellmun wrote:270mm front rotors and 276mm rear rotors in the sport package. With different calipers to suit. You can tell if you have the sport package by whether your car was post 2001, 6 speed manual and came with 16" rims. All MANUAL NB8B's came with the sport brakes in Australia. It was an option in the states.
Autos got povo brakes & painted NB8A rims, thankfully they only sold 1 auto and the king of wheels (Craig) bought the povo wheels, sold em to JBT who put em on Max, which now lives on the Gold Coast.
As far as pads go, have a read Of Caffeines thread re rebuilding his brakes recently.
Users browsing this forum: No registered users and 118 guests
