Wilwood Big Brake Kit - Mania
MXcrazy
Postby MXcrazy » Thu Sep 25, 2008 12:30 am
Just wondering if anyone has purchased the Front Wilwood big brake on sale from mania??
any feedback greatly appreciated :D
andy..
Previous Ride:2000 Evo gold NB8A
Current Ride: 2007 Honda CBR600RR
Sean
Postby Sean » Sun Oct 26, 2008 2:33 am
I haven't personally used this ket, but it is teh same kit that is extremely popular in the US.
I never found the stock braking system to be a problem in my MX5 though, even with 4 times stock power, good rotors and pads mad it pull up just fine.
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sun Oct 26, 2008 11:08 am
from what I have heard it is overkill even for the fast race cars. if its for bling go for it but you do not need it even for the track.
Alex
Postby Alex » Sun Oct 26, 2008 11:26 am
If I was you I would get some nice slotted rotors (you just got pads didn't you)
philz
Wheel guru
Postby philz » Sun Oct 26, 2008 1:16 pm
I think the wilwood kit is pretty overkill.
What rotors are people using? DBA4000? Project Mu? RDA?
mx52nv
Purple Porsche Eater
Postby mx52nv » Sun Oct 26, 2008 1:31 pm
I remember when I had Lucas brake pads, DBA slotted & drilled Gold series brake rotors (for the NA6) and new brake fluid.
After 3 'hot laps', there was smoke pouring out from the front brakes and everything was going spongy :frown:
Think Okibi has a video or pics somewhere...
I had already tried Pagids and a few other highly recommended pads but I soon realised I was going over the thermal capacity of the braking system as the car was going so much faster and was braking much harder (this of course is my interpretation for having to literally stand on the brakes to shave off speed).
So I decided to go for the Wilwood kit from Goodwin.
Brian got it to me within 2 weeks :mrgreen:
No complaints since on the braking department 8)
The calipers, rotors and Alumalite centre hats are particularly light. Rear rotors are bigger albeit with the standard caliper (spacer bracket provided) & Porterfield pads all around.
I highly recommend it if you are really pushing some big horsepower (errm say 200 rwkw??? I do not know what is the definition these days :lol: ) and you have reached the limit of your brakes (after using the best pads, rotors & brake fluids). Otherwise, if you have never experienced brake fade, spongy brakes or smoke/fire :shock: after continuous hard braking then it probably is not necessary.
However, if it is for 'bling' (as 16bit mentioned) then at least the Goodwin/Wilwood BBK will fit under most 16"x7" wheels. There are other 'bling' brakes out there (i.e. Brembo, Alcons by Trust, Project Mu, Endless do a 6 small piston caliper :shock: ) for more money but they are usually fronts only and will require much larger wheels (17" & above) and playing with offsets to clear the brake caliper to wheel spoke issue.
I hope this provides more information to make your decision :wink:
Fuzzlet
Postby Fuzzlet » Mon Oct 27, 2008 12:39 am
Im considering getting this kit, but not till our dollar recovers a bit (I'm kicking my self..I was umming over it, then the dollar plunged..). The brakes on my SE have got nothing on my NA. Na was running bendex pads on DBA rotors, SE does admittidly have OEM pads in it (for now). But I figured if I'm gonna do pads and rotors, I mayaswel shell out a bit extra for something more blingy haha
16bit
Postby 16bit » Mon Oct 27, 2008 1:33 pm
for ultimate bling with no budget limits i would get the tarox kit. farkin sweet. 6 or slight overkill 10 piston callipers!!!!!
http://www.tarox.com/en/compact.php
these babys are over twice the price of the ap racing front kit.
Postby Okibi » Mon Oct 27, 2008 2:03 pm
Pity the aussie dollar sux so bad :cry:
wun911
Postby wun911 » Mon Oct 27, 2008 3:04 pm
I like this because it says its super lite 6 piston caliper but it dont give the specs on the actual weight. Pitty you cant fit smaller lighter 15 or 14" rims over the larger 12" rotors.
http://www.wolverineperformance.com/miata%20brakes.htm
every ounce counts
PUR157
Postby PUR157 » Mon Oct 27, 2008 4:04 pm
But the bigger rotors will weigh more!!!
Oneness of Man and Machine
Daz 27
Postby Daz 27 » Mon Oct 27, 2008 9:34 pm
PUR157 wrote:But the bigger rotors will weigh more!!!
the bigger rotors in the Goodwin kit weigh less than standard NA6 rotors.
mx52nv
Postby mx52nv » Mon Oct 27, 2008 9:42 pm
Daz 27 wrote:the bigger rotors in the Goodwin kit weigh less than standard NA6 rotors.
Correct.
No idea about the brake rotor for the Tarox MX5 kit (went to the site and got fed up looking around :lol: )
wun911
Postby wun911 » Mon Oct 27, 2008 9:49 pm
two piece rotors and the half of it is aluminum, and its considerd rotating mass dreams can come true
every ounce counts
PUR157
Postby PUR157 » Tue Oct 28, 2008 1:46 am
:oops: Smartarse statement cheerfully withdrawn... :mrgreen:
Users browsing this forum: No registered users and 209 guests
