Thunk thunk on braking
marcusus
Postby marcusus » Mon Sep 22, 2008 7:26 pm
I've noticed that when I'm going slowly on the brakes, I can hear a repetitive thunking/creaking. It happens periodically and proportional to the speed I'm doing ie if I'm slowing down, the thunks slowly decrease in frequency until I come to a stop. There's no thunking when I'm off the brakes ie if I'm on a downhill and don't apply brakes, I don't get anything, but if I apply the brakes, the thunking kicks in.
Any suggestions? I won't have a chance to have a look at anything until the weekend, so I thought I might get some preliminary info first.
For those that don't know, it's a NB8A without any modifications to my brakes/pads/rims, but I do have coilovers, a front strut brace and a FM butterfly brace. The pads are wearing a bit thin too, but I would think that having thin/no pads would result in a squeal, not a thunk.
AJ
Postby AJ » Mon Sep 22, 2008 7:36 pm
bushes??.......sway bar bushes maybe?
XMX5 Rogues
Postby manga_blue » Mon Sep 22, 2008 7:37 pm
1. Flat spotted tyre(s)
2. Loose wheel nuts
3. Damaged brake rotor - warped or cracked
4. Collapsing wheel bearing
marcusus
Postby marcusus » Mon Sep 22, 2008 7:56 pm
AJ wrote:bushes??.......sway bar bushes maybe?
Would these cause a repetitive sound only when on brakes? Doesn't seem intuitive for them to do so. If they did anything, it'd clunk once and that'd be it until you came to a stop.
manga_blue wrote:1. Flat spotted tyre(s)
2. Loose wheel nuts
Shouldn't be 1 or 2 because there's no sound if I'm not on the brakes. Although if it's possible that it can be these causing the noise only on brakes, what's the explanation behind it?
I'm guessing 3 and 4 won't be easy for me to check by just getting under the car...
Postby sliq » Mon Sep 22, 2008 9:13 pm
i had a problem similar to that marcus. turns out there was a loose wheel nut.
marcusus
Postby marcusus » Mon Sep 22, 2008 10:08 pm
Sasso wrote:The track day probably wrecked your brakes. Get them machined and new pads. I'd do it before putting the brake bias valve on too.
It never did it before, and I didn't drive any differently than before. Didn't use the handbrake either. Might be worth getting looked at along with the other suggestions.
sliq wrote:i had a problem similar to that marcus. turns out there was a loose wheel nut.
Hmmm... I'll definitely check the nuts. I swapped my rims over on the weekend. I'm just surprised that it only makes a noise when braking rather than all the time. I might go tighten them up now since that one's quite easy to do.
Any other suggestions?
Postby manga_blue » Tue Sep 23, 2008 12:10 am
2. Loose wheel nuts
I've had flat spotted tyres. Track day is the easiest way to get them. They were only obvious at low speed and on the brakes. Don't ask me why.
marcusus
Postby marcusus » Tue Sep 23, 2008 7:31 pm
Interesting. The good thing is these are my spare set of tyres which are going to be replaced by something a bit grippier for the track. However, I didn't take these tyres to the track recently (although they've been on the track before). Can you be a bit more descriptive with the noise you were experiencing so I can compare? Mine's more of a creak/groan combined with a thunk. It kinda sounds like something is flexing.
I tried tightening all the wheel nuts. None of them were loose, but they're all now extra tight. It didn't make a difference, but it was worth a shot.
marcusus
Postby marcusus » Tue Sep 23, 2008 7:59 pm
Sasso wrote:flat spots go thunk thunk, well if you have a busted axle anyway. But the whole car would be vibrating if you had a flatspot.
I should probably take you for a quick drive and see what you reckon it could be...
Meanwhile, could this be a likely cause?
marcusus
Postby marcusus » Wed Sep 24, 2008 11:36 pm
Sasso wrote:prolly saturday or wednesday night, come pick up the brake valve too.
Well tonight's no good. And I might be rather hungover on Saturday, but I'll see. If I'm intact enough to go for a drive, I'll let you know.
Any other suggestions from anyone?
philz
Wheel guru
Postby philz » Thu Sep 25, 2008 10:07 am
From the brake pads thread, so we don't interfere with the thread topic.
Hmmm... mine's more half half. It groans a bit when it does it on mine. Does yours do it proportional to the speed you're going?
Well while driving it's less evident, because you have much more road,tyre,wind and outside noise.
But if you listen closely you can just hear it when it goes over uneven road, with the "thunk"
It's much more noticeable if you are going really slowly- say a car park for example, doing speed of less than 10km/h, and if the concrete slabs aren't joined together properly, you'll hear a thunk thunk, or clunk clunk, once you go over the uneven bump,oOr over a speed hump.
So I would say its proportional to the speed, because if I'm going 60km/h then thunk will be faster.
JBT
Postby JBT » Thu Sep 25, 2008 12:46 pm
marcusus wrote:Any other suggestions from anyone?
Look for missing anti-rattle bits and/or take it to a reputable brake specialist for diagnosis.
marcusus
Postby marcusus » Thu Sep 25, 2008 6:54 pm
philz wrote:Well while driving it's less evident, because you have much more road,tyre,wind and outside noise.
Here's the thing though. When I'm going slow and not on the brakes, there's definitely no sound. It's only when I apply the brakes that I hear anything.
As mentioned, it's hard to test at normal driving speeds, but I'm fairly sure it's not there unless I'm actually on brakes.
JBT wrote:Look for missing anti-rattle bits and/or take it to a reputable brake specialist for diagnosis.
I intend to have a look at it this weekend and see if I can find anything. If not, I might head up to Mania and get them to have a looksee.
Users browsing this forum: Google [Bot] and 5 guests
