Weds Sport TC105N
robbie9394
Weds Sport TC105N
Postby robbie9394 » Thu Aug 28, 2008 4:00 pm
Hi all,
I have an NB8B, was wondering if anyone could confirm if the TC105N 15x7 +20/+35 offset would clear my larger stock calipers?!
Does anyone have 15x7 +20 offset on their NB?? If so, did u need to roll your guards?
Any help will be appreciated as i cannot test fit these before i order them from overseas.
Cheeeeers!
zoomzoom
Weds Sport TC105N
Postby zoomzoom » Thu Aug 28, 2008 7:35 pm
I had a set of 15x7 +24 on for a little bit. The tyres were only 195 but were a little oversize at 55 profile(I was only borrowing them) The rear cleared guards just, with 2 degrees neg camber, the fronts wwould catch on the lip of the guard when the suspension was compressed whilst turning like going in a driveway, and the tyre would bounce up and touch the plastic inner(being higher) when I hit a bump. But with the right size tyres neither may have been a problem.
I think the nb may have a little extra clearence in the front arches too, mine was on na6, as for brakes I couldn't say, I have the same as you and most 15s fit...just, but some such as enkies dont. Would be good if you could get them test fit on another car first.
Tim
Sasso
Weds Sport TC105N
Postby Sasso » Thu Aug 28, 2008 9:43 pm
Nice choice of wheel, Im pretty sure they should fit without rolling, my friends 15x8+26 (i think) with wide semi's fit his NB without rolling, so should these. Be sure to post pics :D
robbie9394
Weds Sport TC105N
Postby robbie9394 » Sat Aug 30, 2008 12:56 am
Thanks for your input guys
But i need to know that these WILL fit my car before i order them ...
The larger calipers have been a pain when trying to find brake pads or wheels etc etc ... :shock:
I can't order them and "hope" that they will fit.
As mentioned earlier ... most 15x7's will fit, but SOME DON'T eg, enkei RPF1's :evil: :evil: :evil:
Sasso
Weds Sport TC105N
Postby Sasso » Sat Aug 30, 2008 10:56 am
robbie9394 wrote:Thanks for your input guys
You should probably give dimentions to the wheel maker or seller and get them to measure it. Get 16's if you're worried.
Users browsing this forum: No registered users and 124 guests
