Need wheel/tire thoughts please
SuperMazdaKart
Postby SuperMazdaKart » Mon Aug 11, 2008 7:42 pm
wheels are too big & too heavy for the car simply. being chrome it's probably a flashy design but bought cheap. something that might of been influenced from the movies Fast & the Furious. has she dríven your car for a comparison? she ought to get rid of them for some nice standard MX-5 wheels or a new set of aftermarket wheels in 15" size. she could probably get a decent price if she sells the 17"s.
the MX5 SE has 17" wheels but they'd be made reasonably lightweight for the size & the SE also has a turbo to push them along.
chances are Adam has a few sets of wheels he might be able to sell lol.
Fatty
Postby Fatty » Mon Aug 11, 2008 7:47 pm
wot he said
bigdog
King of the kennel
Postby bigdog » Mon Aug 11, 2008 10:15 pm
Get her back on original NB 16 inch rims with some decent tires (Michelin Pilot Preceda II, Toyo T1R, Bridgestone Adrenalins, in 205/45x16 profile) and a good wheel alignment and she should be sweet. If the car has lots of miles on it (160K +) it might need new shock absorbers and or springs. Your local forum crew can no doubt suggest the best places to get all this done. I wouldn't mind betting she has been driving on cheap tyres (Nankangs etc) and that will be a lot of the problem. The wheels must be really crappy to be porous enough to let the tyres down :shock: There are plenty of good after market wheels too, but OEM would be the simplest way of solving this problem. Give her a drive of your car Gail so she can see what she's missing out on :D
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Tue Aug 12, 2008 2:36 pm
yeah i love my adrenalins. they have awesome grip. as per my post in ot lounge i kept up with a gallardo spider through mt nebo on the weekend with them. he was no slouch either - brakes were smoking when we pulled over. go the adrenalins if you can get a good price. the pursuit cop also had them on his aurion so the cops are onto the secret too.
Postby bruce » Tue Aug 12, 2008 2:56 pm
I agree. 'Most' chrome wheels are cheap and nasty and I agree with the puncture repair guys. Stick those wheels on ebay and sell em to a ricer. Go back to the stock wheel fitment with good brand name tyres and I'm sure the car will handle a lot better.
SuperMazdaKart
Postby SuperMazdaKart » Tue Aug 12, 2008 8:00 pm
what? you didn't tell her the deluxe vibrator joke?
Fatty
Postby Fatty » Tue Aug 12, 2008 8:02 pm
gail, i'd suggest that she replaces the gearbox oil before she spends big dollars on a gearbox overhaul. it could be as simple as that, hopefully.
if your friend has trouble finding some stock wheels (the 16's can be expensive) i'm sure some of the crew here could recommend some decent lightweight aftermarket rims. or she could get some 15's for it? altho i think you have to be careful with 15's as some fit over the bigger nb8b brakes, and some don't. but again people here can offer guidance with that.
Hellmun
Postby Hellmun » Tue Aug 12, 2008 9:21 pm
Might want to point her to the 15" star-corps. They seem pretty common and are light. Plus you can get a few different finishes she might like.
The redline lightweight shockproof gearbox oil I used really smoothed out my gearbox.... It was notchy and had resistance into 3rd gear especially. I thought the syncho's were damaged and I might be up for a rebuild but just the oil made the difference. It is expensive oil but it does last 80,000km's.
Benny
Postby Benny » Wed Aug 13, 2008 7:11 pm
I had a set of chrome wheels on my previous 5 and had similar problems, although my tyres went down very slowly.
Before you all point the finger, these were quite low weight and 16 X 7's.
I was continually having to pump up 2 tyres and couldn't work out why.
I went to my tyre dealer and tried to find out where they were leaking, even put them into a tub of water to check for bubbles, but all to no avail.
So he took off one of the tyres, and we discovered that the chrome plating was starting to bubble on the INSIDE bead of the rim, and this was causing a very, very slow leak.
The chrome on the outside was perfect, so I wire brushed the inside of the rim to get off all the flaky bits, then painted it with some mastic-like gunk, and the problem went away.
I sold the car not long after, so I can't tell you if the fix worked forever or not, but I reckon he would have gotten a shock when the new owner went to put new tyres on, and the tyres were virtually stuck onto the rim!
Chrome plating is great as it is a tough finish and looks good, but if the metal underneath is not prepared 100%, then problems can occur later on.
I have some experience with plating metals and I know how important the preparation is.
Even if the metal is well prepared, just leaving it out in the air for a day or 2 before the 3 stages of plating are done, can ruin the plating.
To chrome plate something first requires you plate the object in copper, then nickel, then the chrome is plated on after that.
Any little bit of dust or water that comes into contact with the item before or inbetween the 3 platings can ruin it, so it is a very fussy operation if you want it done properly.
Postby sliq » Thu Aug 14, 2008 12:12 am
don't forget the wheel alignment..!
some good set of wheels will also reduce the vibration you get through the actual steering wheel.. you'll know one of your wheels are buckled if u feel there is a tendency for the steering wheel to vibrate when travelling at more than 80-100km/h.. don't ask me how i know :roll:
Adam_NAclubman
Postby Adam_NAclubman » Thu Aug 14, 2008 3:14 am
SMK was right, I would have sold my 15" Volks with good Yokohama rubber for at the most about half what she probably paid for (I'm guessing here) rubbishy Australian market wheels and who knows what tyres.
Good to hear its sorted though. And enjoy Fiji
