Adjusting Koni shocks
Garry
Postby Garry » Sun Aug 10, 2008 4:05 pm
Remove the spring or use a spring compressor to compress it then slide the bottom spring perch along the shock body to reveal a circlip on the shock body. Move the circlip to the desired groove in the shock body then slide the bottom spring perch back till it rests on the circlip and reinstall the spring or remove the spring compressor. Each groove changes the ride height around 12mm I think.
