NC Whiteline sway bars
- Charlie Brown
Install the front bar only and balance goes out the window. You will understeer dramatically.
I have them fitted and for the road the fronts are set on “soft†and the rears on either the soft or centre position. On the track the rear one goes up to full hard. Full hard for the road tends to oversteer slightly through round-abouts with spirited driving.
As for the S2000’s, snap oversteer is caused by them backing off through corners when on the limit. The same thing will happen to a MX-5.
Can i have an estimate of how long would a workshop take to install f&r sway bar?
I've been told the rear ones are quite quick and straight forward, however the fronts are a little more complex?? Been quoted around $160, im considering just going through with it as i'm pleased with the quality of workmanship.
- Charlie Brown
Rear 10 minutes. Don't need to jack the car up.
Front, using Mazda supplied jack and a few sockets. About 50 minutes with help to guide the new bar through the maze of tubes and chassis bits.
There is a step by step guide on Miata.net for those thinking about doing the job themselves.
Mania will fit them for $60 for the pair. If you're there to pick up the bars, and can't be arsed getting under the car to fiddle around with the fitting yourself, might as well pay them to install it. Not too much compared to the prices quoted for other places to fit the bars, and you might as well make the most of your time there if you've made the trek
I'm sticking with the eibach and have no intention on installing them myself, rather be confident there on properly.
- Garry
The rear is a 10min job, the front is a PITA. I'd gladly pay Mania $30 to fit the front one.
- JBT
Raising the dead here.
I now have Whiteline adjustables supplied and fitted by MX-5 Plus
. Set soft front and mid rear. The transformation is just astonishing.
- Charlie Brown
JBT wrote:Raising the dead here.
I now have Whiteline adjustables supplied and fitted by MX-5 Plus. Set soft front and mid rear. The transformation is just astonishing.
That took you long enough to put on John.
Now you need to consider some lowering springs. If you don’t want to drop it much get the Racing Beat springs as they only drop it 10mm.
See you at NatMeet for the charge up the hill.
- JBT
Haha CB, I always put off to tomorrow what can be done today
. Look forward to catching up at Natmeet and discussing these springs of which you speak. I'm not running the hill at Natmeet - will play at the funzykanah with Mrs JBT instead.
- Garry
Indeed. Makes you wonder why Mazda chose the one's they did.
- Old Dude
So these bars are that much better than the standard sway bars
When I was a younger man we used to put K mac sway bars on the old holdens, but I thought with the 5 they had them pretty good as standard, might have to consider these.
Old Dude
Old Dude
MX 5 2001 Grace Green
NB8B
NB8B
- JBT
Yes, they do have them standard. However, the NC does have a fair bit of body roll which is not apparent until you see the photos
or fit after market stiffer sway bars
. Apart from the vast grip and turn in improvements, the normal road "feel" changes too and, to my mind and recollection, makes the NC feel very reminiscent of the NA. I gotta tell you that, as an old fart, I was a sceptic.......but now a true believer.
- Old Dude
Thanks JBT, I have the NB8B so I suppose it would be the same with that as well.
Old Dude
Old Dude
NB8B
NB8B
- JBT
