Page 1 of 2
Braided Brake Lines? worth it?
Posted: Sat Jul 19, 2008 7:20 pm
by Mr Starlet
Hi all
Just seeing what your thoughts are regarding braided brake line, are they worth installing? I've came across numerous reviews that recons they're a waste of money, they recon there's no noticeable pedal improvement, are they even road legal here in QLD?
Minh
Posted: Sun Jul 20, 2008 1:39 am
by Alex
you can get ADR approved ones (legal)
lots of people say it's better to get a master cylinder brace though
Posted: Sun Jul 20, 2008 12:17 pm
by mr_rotary
I beleive they are worth every cent. Brake pedal feel is a LOT firmer, no squishy feel and you can feel the difference even on the street.
Posted: Mon Jul 21, 2008 11:37 am
by wun911
Its around the $200 mark for ss lines (ADR aproved) + 8 bucks for new fluid.
I just installed mine about 2 weeks ago (2001 NB8B). I think the older your OEM lines the more difference you will notice. Considering old lines will give and expand more.
I do notice a difference in \"firmness\" I had to bleed in new fluids so that may also have contributed to the more \"firm feel\". I estimate its around 10% more firm, dont have to press the pedal as deep to have bite etc.
Its not a missive wow difference but overall Im happy I installed the ss lines.
Posted: Mon Jul 21, 2008 12:10 pm
by Mr Starlet
So the ones that are ADR approve would have some sort of tag or engraving that say so?
Posted: Mon Jul 21, 2008 12:27 pm
by 16bit
i have seen a review at double the psi of most full brake applications and the difference was about 1 - 2 % in the expansion of the lines - good luck noticing the difference.
Posted: Mon Jul 21, 2008 1:15 pm
by wun911
Did the review compare new lines to SS lines? I think the difference is greater as the line gets old...
If you press the pedal hard on old lines you can visibily see the lines expand in that case surely it cant be a 1% differnece.
Posted: Mon Jul 21, 2008 1:28 pm
by 16bit
they were quite old and it was done on a proper measuring machine of sorts. i will have a look and try to find it.
Posted: Mon Jul 21, 2008 6:47 pm
by CT
Every proper race car in the world uses braided lines...you can use that as a reference.
Roads cars don't really need them but even HSV and FPV fit them to their performance models.
Posted: Mon Jul 21, 2008 6:50 pm
by AJ
wun911 wrote:Did the review compare new lines to SS lines? I think the difference is greater as the line gets old...
bloody hell wun!!!........your eyesight must be unbelievable, no WAY brake line expansion is visible to the naked eye
Posted: Mon Jul 21, 2008 11:46 pm
by Sheck
i found zero difference when i fitted mine
Posted: Tue Jul 22, 2008 9:14 am
by 16bit
CT wrote:Every proper race car in the world uses braided lines...you can use that as a reference.
I would say thats got more to do with reliablity under extreme conditions then how much they expand - that and manufacturors of road cards don't do it on a lot of cars because its more expensive and the normal lines work just fine.
Posted: Tue Jul 22, 2008 9:29 am
by Steampunk
16bit wrote:CT wrote:Every proper race car in the world uses braided lines...you can use that as a reference.
I would say it's got more to do with reliability under NORMAL conditions James
Posted: Tue Jul 22, 2008 10:55 am
by 16bit
if by normal you mean extreme then yes
Posted: Tue Jul 22, 2008 1:00 pm
by wun911
I think I found the article 16bit read.
http://autospeed.com/cms/article.html?&A=2679Its only a 1% difference
