Braided Brake Lines? worth it?
Mr Starlet
Postby Mr Starlet » Sat Jul 19, 2008 7:20 pm
Hi all
Just seeing what your thoughts are regarding braided brake line, are they worth installing? I've came across numerous reviews that recons they're a waste of money, they recon there's no noticeable pedal improvement, are they even road legal here in QLD?
Minh
Alex
Postby Alex » Sun Jul 20, 2008 1:39 am
you can get ADR approved ones (legal)
lots of people say it's better to get a master cylinder brace though
mr_rotary
Postby mr_rotary » Sun Jul 20, 2008 12:17 pm
I beleive they are worth every cent. Brake pedal feel is a LOT firmer, no squishy feel and you can feel the difference even on the street.
wun911
Postby wun911 » Mon Jul 21, 2008 11:37 am
Its around the $200 mark for ss lines (ADR aproved) + 8 bucks for new fluid.
I just installed mine about 2 weeks ago (2001 NB8B). I think the older your OEM lines the more difference you will notice. Considering old lines will give and expand more.
I do notice a difference in \"firmness\" I had to bleed in new fluids so that may also have contributed to the more \"firm feel\". I estimate its around 10% more firm, dont have to press the pedal as deep to have bite etc.
Its not a missive wow difference but overall Im happy I installed the ss lines.
every ounce counts
Mr Starlet
Postby Mr Starlet » Mon Jul 21, 2008 12:10 pm
So the ones that are ADR approve would have some sort of tag or engraving that say so?
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Mon Jul 21, 2008 12:27 pm
i have seen a review at double the psi of most full brake applications and the difference was about 1 - 2 % in the expansion of the lines - good luck noticing the difference.
wun911
Postby wun911 » Mon Jul 21, 2008 1:15 pm
Did the review compare new lines to SS lines? I think the difference is greater as the line gets old...
If you press the pedal hard on old lines you can visibily see the lines expand in that case surely it cant be a 1% differnece.
every ounce counts
16bit
Postby 16bit » Mon Jul 21, 2008 1:28 pm
they were quite old and it was done on a proper measuring machine of sorts. i will have a look and try to find it.
CT
Postby CT » Mon Jul 21, 2008 6:47 pm
Every proper race car in the world uses braided lines...you can use that as a reference. 8) Roads cars don't really need them but even HSV and FPV fit them to their performance models.
AJ
Postby AJ » Mon Jul 21, 2008 6:50 pm
wun911 wrote:Did the review compare new lines to SS lines? I think the difference is greater as the line gets old...
bloody hell wun!!!........your eyesight must be unbelievable, no WAY brake line expansion is visible to the naked eye :lol:
XMX5 Rogues
Sheck
Postby Sheck » Mon Jul 21, 2008 11:46 pm
i found zero difference when i fitted mine
16bit
Postby 16bit » Tue Jul 22, 2008 9:14 am
CT wrote:Every proper race car in the world uses braided lines...you can use that as a reference. 8) Roads cars don't really need them but even HSV and FPV fit them to their performance models.
I would say thats got more to do with reliablity under extreme conditions then how much they expand - that and manufacturors of road cards don't do it on a lot of cars because its more expensive and the normal lines work just fine.
Steampunk
Postby Steampunk » Tue Jul 22, 2008 9:29 am
I would say it's got more to do with reliability under NORMAL conditions James :P
16bit
Postby 16bit » Tue Jul 22, 2008 10:55 am
if by normal you mean extreme then yes
wun911
Postby wun911 » Tue Jul 22, 2008 1:00 pm
I think I found the article 16bit read.
http://autospeed.com/cms/article.html?&A=2679
Its only a 1% difference :?
every ounce counts
Users browsing this forum: No registered users and 303 guests
