A popular question: What tyres?
kenson
Postby kenson » Fri Jul 18, 2008 6:39 pm
Hi everyone,
I own a 2001 NB8B with standard rims
Rims: 16 x 6.5, 40 offset
Tyres: 205 / 45 / 16
Now I am looking at getting some Buddy Club P1 Racing SFs Gunmetal
Rims: 16 x 7, offset 42
Tyres: 205 / 45 / 16 OR 215 / 45 / 16 OR 215 / 40 / 16 :?:
I know that most people would recommend the 205's. But would I have any issues going for wider wheels? I have completely stock suspension and I have tried searching already. Sorry is this topic has been covered!
I am getting the rims at $299 each (RRP is $326) if you're wondering 8)
Thanks for all the help!
Kenny
StanTheMan
Postby StanTheMan » Fri Jul 18, 2008 8:45 pm
we also need to know what you expect from your tyre.
Tyres are generally a compromise between a few things you feel are important.
eg: tyre wear, grip handling and what kind of enviromet you'll be using them in. Like track work. or weekend club drives. or just commuting between home & work or a bit of all of the previous.
be aware, opinions are also subjective and of couse I'll personally be preaching a tyre that really only good for a combination of weekend mountain Touge and occasional track work. even with your stock as rock suspension.
:mrgreen:
kenson
Postby kenson » Fri Jul 18, 2008 9:23 pm
StanTheMan wrote:we also need to know what you expect from your tyre.
:mrgreen:
Thanks for the reply Stan! Every bit of advice counts since I don't really know
This car is my daily and I do like to go for a spirited drive here and there on weekends. I think I'm leaning more to the 205/45/16 combo due to price and availability. Also looking for something with a "rim protector" :roll:
Pretty sure anything will be better than my 6-7 year old original tyres on the car. And yes, they still have a huge amount of tread on them. In the last 7 years it's only put on about 30 000 k's :D
mx52nv
Purple Porsche Eater
Postby mx52nv » Fri Jul 18, 2008 11:51 pm
Hi kenson,
Speak to Kerry or Graeme at Bridgestone Bentley (Tel: 9458 4586) about some Adrenalins RE001s. Tell them Les sent you. I guarantee you won't be disappointed with both the performance of the tyres or their knowledge. You might catch a glimpse of Kerry's race car or any of the race cars they set up which would be reason enough to drop by.... :lol:
Current Club Prez of WA and many of the club cars have been set up by Kerry Wade. Real unassuming guy but hugely talented driver. He personally spent a lot of time getting the MX5s to handle right over the last few years (mine included).
kenson
Postby kenson » Sat Jul 19, 2008 1:41 pm
mx52nv wrote:Hi kenson,
Sweet! Thanks Les. I'll have to drop by then. Had a look at the other RE001 thread and it seems people can get it for about $199 a corner which is fine with me
Postby Mr Morlock » Sat Jul 19, 2008 2:24 pm
You got some good responses. For those just driving their car day to day and not pushing too hard an all rounder which gives adequate grip dry and wet and wears reasonably is likely to suit most drivers. Track driving is a different ball game and whilst some might disagree if you had the budget a separate set of wheels and tyres might be an option for that situation. Soft compound tyres normally do not have longevity as far as I am aware.
Mick93
Postby Mick93 » Sat Jul 19, 2008 5:17 pm
If you can go to a Bridgestone tyre centre. I priced Sydney for RE001 (in 15's) and everywhere wanted $147. I went to a Bridgestone tyre centre $117. I ended up buy Toyo R1R's and they are awesome, every bit as good as my RT615's.
Postby bruce » Mon Jul 21, 2008 12:33 pm
Go to a tyre shop and buy 4 black round ones that fit. Easy.
mx52nv
Postby mx52nv » Thu Jul 24, 2008 1:17 am
Ian, our Motorsport Captain (WA), runs 225s all around. I think he said that he had tried some other size front to rear but not sure what it was.
However, I do remember that he tested plenty of tyres before settling on the 225s all around for maximum traction (he had like 200 rwkw and traction control).
In all honesty, I like having a little oversteer exiting most corners and in the MX5, it usually is very controllable.
Charlie Brown
Postby Charlie Brown » Thu Jul 24, 2008 10:17 am
fundies wrote:Just wondering if anyone has run say, 225 tyres on the rear, 205 on the front? Is this good or bad for thr MX5? Seems to me that MX5's suffer more from oversteer than understeer, and a wider rear tread may help dial this out in the dry.
MX-5’s don’t suffer from oversteer. If you are experiencing oversteer then you have one or a combination of the following problems:
• alignment is out
• incorrect tyre pressures
• worn suspension parts
• hard/old tyres on the rear
Going to a 225 tyre on the rear will only add to your woes due to the increase in weight and the sloppy side walls on a 6.5" or 7" rim.
Back to kenson’s question; stick with the 205x45 section on that size rim for a daily drive.
The 215x40 will give you a harsher ride due to the wall height and is 2% smaller in circumference, meaning more engine revs. The 215x45 is heavier and is 2% larger in circumference.
rjastra2
Postby rjastra2 » Fri Jul 25, 2008 10:40 am
as in the lotus elise, ferrari, porsche, corvette..................you get my drift.
Those cars are either mid/rear engined or have a surplus of power (corvette). An MX5 has none of these characteristics :)
kenson
Postby kenson » Fri Jul 25, 2008 11:20 am
• alignment is out
Thanks Charlie
I have gone for the lighter rims and the RE001's in the 205x45 size :D
TieNN89
Postby TieNN89 » Sat Jul 26, 2008 12:34 am
kenson wrote:I have gone for the lighter rims and the RE001's in the 205x45 size :D
How much did the tyres cost you?
Have you got it yet
When you get it lift up the rim then when the re001 is put on lift it up lol
kenson
Re: Re:
Postby kenson » Sun Jul 27, 2008 7:20 pm
Have you got it yet
Rims were $1200 (Saving of $104 + $150 postage). Tyres are $220 each. I didn't shop around as I was short on time. It seems the cheapest people can get are around $199. ~$80 loss isn't too bad for the amount of time involved
Still playing the waiting game. I should get them by Wednesday. The bad news is I'm leaving on Wednesday to go to Copenhagen (Denmark) for work :cry:
How are you finding the new exhaust and rims/wheels Tien?
TieNN89
Re: A popular question: What tyres?
Postby TieNN89 » Sun Jul 27, 2008 11:12 pm
The tyres stick pretty well for the price and I've only done like 800ks max yes i did that since Thursday arvo
Love the look of gun metal
as for the exhaust love it too but its kinda a bit too loud
Normally cruising around its ok i don't mind the loudness as when your crusing you don't hear much
but when your going up a mountain like i did today you really need ear plugs LOL
mainly because I'm on low gear and on high rpm = to loud and seeing as I'm going up a mountain i'd be loud for the next 5 - 10 min or so
