issue with brakes/driveline
stevesports
Postby stevesports » Sat Jun 07, 2008 2:02 pm
Hey guys, i have an issue with the brakes (at least that's what i think it is)
When i brake, the front left or right ( i think it is both) is making this knock sound. This happens once only. If i take my foot off the brake and reapply the brake, it doesn't make teh sound anymore. I'm not too sure what this is exactly.
i think it is the brake pads unsticking to something? i'm not too sure.
cheers for the help.
Fatty
Postby Fatty » Sat Jun 07, 2008 2:07 pm
was it shuddering .. was it in the wet, or slippery conditions? it could have been you ABS kicking in momentarilly... ?
stevesports
Postby stevesports » Sat Jun 07, 2008 2:09 pm
nah. It isn't the ABS. There is no difference in brake feel.
Matty
Postby Matty » Sat Jun 07, 2008 2:17 pm
Could be a loose bolt or something.
Also, do you have the springs and shims on the pads?
Sasso
Postby Sasso » Sat Jun 07, 2008 2:18 pm
Could be your suspension bushes clunking.
stevesports
Postby stevesports » Sat Jun 07, 2008 2:22 pm
Matty wrote:Could be a loose bolt or something.
yeah i had a feeling it might be a loose bolt. And yeah the shims are on the pads, i dunno how to check springs.
Matty
Postby Matty » Sat Jun 07, 2008 3:24 pm
the little U or W springs - you should be able to see them.
fattima
Postby fattima » Sat Jun 07, 2008 3:50 pm
I had a loose brake line make a similar noise one, was taping on the body. Check the springs as already mentioned and that everything is done up tight.
Users browsing this forum: Google [Bot] and 237 guests
