Camber
ducktape69
Camber
Postby ducktape69 » Tue Jun 03, 2008 2:03 pm
just wondering how much the driver side front camber would/should change when sitting in the car.
eg: -0.5degrees without sitting in drivers seat...what would this change to AFTER sitting in the car for an average sized person?
Sam
AJ
Postby AJ » Tue Jun 03, 2008 7:04 pm
yep, to get totally accurate wheel alignment, driver in the car is a must............not necessary unless you're a serious racer but............or pedantic :mrgreen:
XMX5 Rogues
ducktape69
Postby ducktape69 » Fri Jun 06, 2008 12:05 am
well i am a bit pedantic haha.
anyone got any ideas on this?
Charlie Brown
Postby Charlie Brown » Fri Jun 06, 2008 9:15 am
For me in the NC between 0.2 and 0.3 degrees more negative has to be placed on the drivers’ side. It will vary depending on your weight.
The best way is to have the aligner connect everything up to the front and rear wheels and then get in the car. Take a reading and then get out and take another reading. The difference is the required variation for the drivers side.
ducktape69
Postby ducktape69 » Fri Jun 06, 2008 3:24 pm
do you mean the extra weight gives more POSITIVE camber? i thought the extra weight adds more NEGATIVE camber?
