super urgent help needed
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Sat May 24, 2008 3:49 pm
I am changing over my disks at the moment and have run into my first problem. the new disks are too thick to fit in the caliper. how do I re set the height of the cylinder?
Postby orx626 » Sat May 24, 2008 4:29 pm
Use an old pad & a G-clamp. 8)
Postby Mr Morlock » Sat May 24, 2008 4:34 pm
Sounds to me like the pistons need to be pushed back in the caliper- you can do this by using a lever, screw driver or the like. When you change pads for example on most cars the pistons need to be retracted to get the new pads in a thicker new disc is\" taking up more room\"
JBT
Postby JBT » Sat May 24, 2008 4:43 pm
DO NOT PUSH BACK THE REAR PISTONS :!: They must be adjusted using an allen key. Access to the allen head screw is under a blanking bolt.
16bit
Postby 16bit » Sat May 24, 2008 6:33 pm
thanks guys - crisis avoided. I managed to find instructions on miata dot net. just wondering though I have reversed in the undercover carpark the car is in and tried the brakes out. they are a little underwhelming is this because the front pistons need to settle or will the bedding process improve them?
JBT
Postby JBT » Sat May 24, 2008 6:51 pm
Make sure the rears are adjusted. Then you'll have to bed them in by doing a few heavy brake applications without fully stopping. Some info here http://www.tirerack.com/brakes/tech/techpage.jsp?techid=85
16bit
Postby 16bit » Sun May 25, 2008 9:56 am
i went for a small drive last night and they got much better with the trip. I will do a few more k's today - thanks to all
