Hi guys
I have come accross some wheels and just wanted to see what peoples view is on the size and how or if they will fit my NB8A
They are: 17x8 +19 offset and 17x8 +14 offset centre hole on the rims are 57mm.
Mark
will these fit an NB8A? PICS
99 mx5, Brilliant Black with hardtop, cusco f/brace,intake and AVO turbo kit awaiting install.Tien SS coilover kit,BD Rollbar,16x7 Work Meister's!!
- Hellmun
- Vehicle: NB8B - Turbo
59.1mm on an mx5.
http://www.949racing.com/index.asp?Page ... D&ProdID=9[/url]
In regards to offset and rim width though, I hope your have your guards rolled and some camber at a minimum. I'm always running 2 degrees + camber, have stiff Tein Monoflex and have rolled guards and I can get rubbing on 215/40/17 road tyres when braking hard going down steep hills. Those wheels are +35 offset 7.5\" wide. Yours are slightly wider and offset further out....
For reference I actually had to roll my guards because of 205/50/15 semi-slicks getting gouge marks. Those wheels are +35 offset as well, the semi's are just 224mm wide I think.
I'm sure you can do it but I'd say you'll have compromises to make you don't particularly want in a street car.
Thanks for the replys guys
I pretty much knew that they would be a verry tight fit and that scrubbing would be a big issue Im not the best workin out offsets and if they will fit but these are the puppies im in lurve with!!! One of the Sexiest wheels i my books-WORK MEISTER S1 JDM Goodness
Ive got Tien SS and my ride is pretty stiff and from what i can see these will need alot of work to fit but it can be done you think......
[/url]
Cheers,Mark
[/url]
Cheers,Mark
Thanks for all the input guys
Ive always wanted to have a setup exactly like this:
http://img291.imageshack.us/img291/6565/dd17090pu8.jpg
with these style wheels-Work meister s1 and plenty of dish
I just want to know how do the get them in there and exactly what offset and width will get me whats in the above
Im not the best when it comes to offsets
Thanks again for your help guys
Mark [/url]
Mark [/url]
- PUR157
Users browsing this forum: No registered users and 342 guests
