Shaky Car
lfg
Shaky Car
Postby lfg » Thu May 15, 2008 5:16 pm
Good Afternoon all
I have just purchased a 1996 na8 which is an immaculate montego blue with a drive around the block 84,000ks. it has the NB wheels also
Just went for a thursday morning drive and going along a freeway once i hit upwards of 90 in 4th my car started rattling like crazy until i got up to 110 and went to 5th and all of sudden felt alot smoother.
I may seem like a newb but hey first manual car and just wondering if some insight from others is around
JBT
Postby JBT » Thu May 15, 2008 5:33 pm
Get a wheel balance and see if that fixes it.
PUR157
Postby PUR157 » Thu May 15, 2008 5:39 pm
That would be the 60mph shimmy
Heed JBTs advice!
It should cure it... if not... maybe some body bracing is in order
Put some photos up on your \"My Car\" page!
And, welcome to the forum!
Oneness of Man and Machine
Col
Vehicle: 10AE
Postby Col » Thu May 15, 2008 5:49 pm
Cold tyres and especially if car has been parked for a while, can attribute to the shakes. If this is the cause, the car should feel better when the tyres heat up. Certain tyres are more prone to this, as they develop a short term flat spot.
Happy 10AE man [#5128]
lfg
Postby lfg » Thu May 15, 2008 5:51 pm
thanks all ill look at a wheel allignment as soon as i get paid and until then I guess ill just take it easy
Matty
Postby Matty » Thu May 15, 2008 9:58 pm
balance, not alignment.
Postby Mr Morlock » Fri May 16, 2008 12:06 am
You did not say where you bought it- perhaps if from a dealer you have a warranty. If you bought it privately then I suggest that you get it checked immediately to determine the cause( don't assume it is wheels even if the most likely) . A simple wheel balance is quick to check and not expensive . Your description tells me to get it attended to pronto.
Garry
Postby Garry » Fri May 16, 2008 9:45 am
While they are doing the wheel balance get them to check for bent rims and out of round tyres. But like the others have said it's probably nothing more serious than a missing wheel weight.
TieNN89
Postby TieNN89 » Thu Jun 05, 2008 9:19 pm
get the wheels balanced and check whether or not one of the wheels is buckled bent ...
as my rear d/s is buckled i can feel vibration when i'm doing 100km/h 110 its a bit smoother same goes with 90km/h but 100km/h is where mine vibrates
Benny
Postby Benny » Fri Jun 06, 2008 10:49 am
If a normal wheel balance doesn't fix it, find a place where they do on-car balancing.
That is, they rotate the wheel while it is still on the car and ad the balance weights where required.
Buckled rims are also a cause for shaking and wheels are often buckled on the inside of the rim where it can be difficult to see them.
If the rims are taken off to blance them, any buckling should be easily noticed.
Don't be too worried about this Ifg, it is a very common problem and is usually easy to fix.
Baxter
Rears
Postby Baxter » Sat Jun 14, 2008 7:52 am
Hi Quite often the shakes are the rear wheels out of balance,Be sure to get all four done.As a rule of thumb if it is the front you can feel it through the steering, the rears the whole bloody thing shakes
Steven
Users browsing this forum: No registered users and 221 guests
