Page 1 of 2
NC Lowering - Newbie question
Posted: Wed May 14, 2008 12:05 am
by Murphster
Forgive me, I am a complete novice at all of this stuff. I always thought a car was just for driving but all of a sudden two weeks of owning an MX-5 and I am reading all about suspension and struts, sways and and brushes and do not have a clue what any of it means!
I want to lower my car though, I have read enough posts about the pro's and the con's and think the extra handling benefits plus the better looks it gives is the right choice.
I think it all seems pretty simple, buy a set of springs, pay someone to fit them. Is that really all there is to it?
I am thinking of the Eibachs, is this the Eibach prokit from Mania?
I do not want the \"boy racer\" look, just a bit lower will do. I have seen pics of Charlie Browns Kings and his look too low at 40mm lower. I am probably looking at no more than 30mm lower.
Am i right in thinking I can get this with the Eibachs? Or is there a way to get the kings but not go as low as Charlie?
It is all very confusing.
Also, anyone know of a place to get them fitted in Brisbane? Is it better to get them to supply too?
Posted: Wed May 14, 2008 9:46 am
by Tezzax5
check your pm's.....
Posted: Wed May 14, 2008 10:05 am
by Garry
You will need to budget in a 4 wheel alignment after it's lowered to avoid uneven tyre where and some funky handling issues. You might like to keep in mind that the minimum legal ground clearance when fully laden is 100mm in most states of Australia. This may determine how low you can legally go.
Posted: Wed May 14, 2008 10:30 am
by Charlie Brown
Murphster,
There’s not a lot of difference between 30 and 40mm lower in appearance and I agree with you that 40mm is too low for general road use. Sure it looks great but some care is needed when negotiating speed humps, dish crossings and those one way metal finger ‘thingos’ that appear in parking areas and drag along the bottom of the car making a hell of a noise.
I’d recommend that you ask Kings (who manufacture in Brisvegas) to make you up a set that’s only 20mm lower. In other words 15mm longer than their normal lowered set. Kings have the same (within 2%) spring rate as the Eibachs. You should be able buy and have the Kings fitted for the same price of just the Eibach springs.
You don’t need to worry about a tower strut, the NC has one standard and the advertised alloy one is just bling.
Sways will make the biggest difference in the way your NC handles. It removes the roll (the lowered springs will also but not to the same extent) and improves quick directional changes but has a down side in that it increases understeer. Adjustable sways help dial this out as you can increase the stiffness in the rears to compensate for the fronts. This understeer really only shows up on the track so I wouldn’t worry about it too much for road use.
Posted: Wed May 14, 2008 11:56 am
by Murphster
Thanks for your feedback guys, Really appreciated.
Charlie, don't get me wrong your car looks great! Just going by some of the comments you made about ground clearance etc..
I ordered a grille from Go Matia this morning and they had some cheapo springs that lowered 13mm - think that is probably not low enough.
Good idea about the King's, I am inclined to agree with you that 20mm may be enough. I just think the car looks better lower. I will give them a call.
Thanks folks.
Posted: Wed May 14, 2008 12:12 pm
by Charlie Brown
20mm also, as Garry eluded, puts you on the legal limit to get the required 100mm minimum clearance.
Posted: Thu May 15, 2008 1:02 am
by DavidM
I'm pretty sure that Kings sell 2 sets of sprins for NC, and one of them drops the car only about 2cm. Friend of mine has them on his NC and the drop is pretty subtle.
He got them (inlcuding fitting) for around $300 if I'm not mistaken.
Posted: Thu May 15, 2008 7:28 am
by Murphster
Thanks David, I have emailed Kings to ask.
Posted: Thu May 15, 2008 9:19 am
by JBT
Member of the Qld Mx-5 Club
Club members get a discount at Fulcrum Suspensions.
Posted: Thu May 15, 2008 3:53 pm
by Mick93
I wouldn't touch King Springs. I was told by many people on this forum when the socks went on my NA to get Konis and King springs. They are the worst spring. They are lower and harder but not progressive. Kings appear to only make cosmetic springs (make your car lower not better). I know I am going to get shouted down by heaps of people but I have been in motorsport for 17 years and have worked in motorcycle racing teams it is very hard to improve suspension you have to decide if giving up ride comfort for looks is worth it. Also there will be a performance loss if you just go for harder springs your car will skip more on uneven roads (read all roads). When my car had Kings it also needed the suspension more regularly inspected and tightened. I can't comment on Eibach springs but they do get a big rap in the US. I solved my problems with coilovers (Arigosta's) and they are awesome it is the best way of lowering your car and if you decide to sell your car whip them out and sell them on the forum they won't last long. The most you will loose is a grand and you will be able to set your car up to exactly to what you want, easily worth the cash
Posted: Thu May 15, 2008 6:02 pm
by Murphster
Kings have come back to me with a quote for springs that drop 30mm, I called Fulcrums and they basically said that that is probably right. They never had anything that is lower than 30mm.
So I have a choice of Racing Beat suspension that drop 13mm, they are only $184 US from Go Miata, which is a decent price.
They have Mazdaspeed ones at $240, but they drop 34mm.
The Eibach's are $224 no idea what they drop but prob about the same.
** These prices are mad when compared to Aussie dealers, even with shipping they seem too cheap to be true. Do I need to be careful of import duty? Would it be much?
Anyway, Fulcrums suggested I measured my car, which aint a bad idea really. So I took a tape measure and measured the lowest part of my car which seems to be the front mud flaps and they were 135mm off the ground, so even 30mm would keep me okay I presume.
Thing is my last car was an SP23, that must have shipped with sports suspension as standard and there were a few places that the bottom of my car scraped the road, the entrance to my carpark for one, it always sounded like my bumbers were being ripped off - I do not want to start having that with my new car. Anyone know how low an SP23 is?
Posted: Thu May 15, 2008 7:50 pm
by DavidM
Mick93, I can only comment on the small-drop King springs in the NC. The car has nothing but springs and compared to stock ...
1. It has better responsiveness.
2. It handles mid-corner bumps better. Stock car was a bit scarry sometimes while now the car takes these more in it's stride.
3. No noticable difference in ride quiality. The car is probably firmer, but it still rides over bumps more like a luxury car.
4. It looks only marginally lower than stock.
Also this particular car has no problems with pot-holes, driveways, etc. I also measured the lowest point on the car, and that was the rubbery mud-flap in front of the front wheels, which was still good 11cm+ above ground.
Not sure what other springs are like on the NC, but I don't see a problem with the Kings.
ps. The car I'm refering to is a hardtop.
Posted: Thu May 15, 2008 8:34 pm
by Murphster
Hi David, Mine is a hard top too (does this make a difference?)
When you say low drop Kings do you know what exactly you bought? They said today they only have 30mm drop springs.
Posted: Fri May 16, 2008 10:30 am
by Charlie Brown
Murphster wrote:Kings have come back to me with a quote for springs that drop 30mm, I called Fulcrums and they basically said that that is probably right. They never had anything that is lower than 30mm.
I think you will find that your NC is a lot lower than 135mm.
Mazda’s official ground clearance is 119mm. I’m sure that this is the cross member sitting under the engine and not the little plastic flaps in front of the tyres although there isn’t a lot of difference between the two.
Kings may have changed the NC spring drop from the ones initially developed with them for my car.
The original spec was to match as close as possible the Eibach/Mazdaspeed springs which were 35mm drop with a 28% increase in spring rate.
One point you need to remember is that the springs will settle. My first set dropped another 10mm after installation, making them 45mm lower than standard. Way too much. They wound a second front set a bit longer to start with and they settled 7mm.
Here’s a little comparison for you. Measuring from the centre of the wheel to the apex of the curve in the guard I had the following numbers;
Standard: Front 385mm, Rear 370mm
My initial King setup settled to: Front 335mm Rear 335mm
My current figures after fronts redone: Installed at 350mm settled to 343mm, Rears installed at 340mm now settled to 331mm.
So if Kings are now saying they only do a 30mm drop, then they have change them since I had mine installed 2 ½ years ago. If it settles to that figure (30mm) then they will be fine.
Posted: Fri May 16, 2008 7:08 pm
by DavidM
I think the hardtop has slighlty different suspension setup from the factory. Not sure if it makes any differene here though.
Yes, 30cm is what I think the claimed drop is. This is what is sais on the box KMFL-40SP ... probably the model number?
