I will be installing Konis & Eibach from an NB into my NA. Is there anything tricky about it?
Will the brake lines foul anything?
They came with the NB strut tops/hats so no spring compressors needed.
Straight forward yeah?
NB struts into NA. Anything tricky?
- Steampunk
- Boyracer
- MX-5 Encyclopedia
The NB suspension bolts straight in...the only thing is they have a longer bolt at the top so they can be a bit tight to fit...I usually loosen the front lower arms at the inner mounts so they drop right out of the way.
just make sure you mark the adjusters before you loosen them so they go back in the same spot.
- Steampunk
Spranga wrote:I thought you had to change the rear spring/perch mounts to make the shock shorter? If you don't the bum will sit up in the air
That is pretty much all that I was worried about.
Apparently you can get the Koni's re-threaded/re-collared so the perch sits lower.
I am crossing my fingers the Eibachssesses springs are lowered ones so at least I will have normal ride height if it does push the ass up.
1red5 wrote:Apparently you can get the Koni's re-threaded/re-collared so the perch sits lower.
Check with Uncle Arthur, I'm pretty sure that is what he had done to his buy Fulcrum. Makes the ride height adjustable with a threaded collar. Looked very good.
Andrew.
Previously, White 95 NA 1.8 Hard Top,Stock standard
Now, 2016 Fiat 500x, 2014 Fiat 500, 2015 ND GT 2.0
- xhonda_boy
- Steampunk
I took pics, but they are nothing special. I'll post them tomorrow from work as I only have 56k dial up at home.
John, so have you done yours yet?
If not then here are the big tips I got that were pretty much necessary in order to get it done right.
Front suspension:
- undo the big, long bolt that attaches the top wishbone to the chassis
- this will allow the top wishbone to drop down so you can angle the strut in
- undo the sway bar end-link so the front suspension can drop down even further
- you need to get someone to put a bit of weight onto the front suspension to bring it down a few centimetres whilst you fit the strut
Rear suspension:
- undo the bolt on the upper wishbone that connects it to the to top of the wheel hub
- undo the sway bar end link to, once again, allow the suspension to drop down further
- get someone who weighs at least 85kg to stand on the rear hub, thus pushing the suspension down, whilst you position the rear strut into place
It'll make more sense once you start to do it
Good luck
Andrew
Front suspension:
Rear suspension:
Good luck
Andrew
