Fornt sway bars and bushing
Posted: Fri May 02, 2008 3:36 pm
by GP14
What do people recommend. Whiteline? Racing Beat? other?
I saw on the whiteline website they have adjustable for $220 and standard for $177. Is it worth getting adjustable?
Also looking at getting bushing. I believe mine are knackered. I saw the post regarding the Energy suspension HyperFlex bushings from the 949racing mob. They seem cheap but i enquired and shipping was US$130. Admittedly that was including the Racing Beat swaybar. Have sent an email without the sway bar to see how much it will end up being. If they end up being too exy what does everyone use/recommend.
cheers
Posted: Fri May 02, 2008 4:47 pm
by Sasso
Not sure where you live but mx5 mania sell Signature sway bars, basically the same as whiteline, but you can powder coat in desired colour, they also come with the super pro bush to match.
Yeah get adjustable. You can tune the balance of the car to your liking.
Bushes, I'd try super pro with more offset for better alignmnet. I thought 949 racing sold them, otherwise try FM.
Posted: Fri May 02, 2008 4:52 pm
by Steampunk
Geoff, I have a non-adjustable front Whiteline, 24mm solid, with their own poly bushes. (stock rear)
Have a drive in mine one day and see if you like the neutrality of it.
Posted: Fri May 02, 2008 5:53 pm
by Charlie Brown
Adjustables are a MUST, otherwise you are just left with fine tuning your alignment to take care of the understeer.
When that doesn't work you need to add adjustable end links ($140 per pair) and preloading the bar to get the balance you require.
I'm assuming that you have an NA if you want to replace the bushes. If it's an NC then you must get the adjustable rear bar as well because the understeer caused by the front bar is impossible to dial out.
Posted: Sat May 03, 2008 4:36 pm
by GP14
Thanks Sasso. Just got a reply from 949. US$45 for shipping. Im considering getting those. Incidently how much are the super pro bushes?
Andrew if your going to the dodgy day on the 18th i'll have a drive then if you don't mind.
Charlie thanks, i am definately considering adjustable. Sorry, yes its an NA
cheers
Posted: Sat May 03, 2008 8:40 pm
by Sasso
no probs.
www.flyinmiata.net look under suspension. They're much more expensive, but arguably better, especially the offset ones, more people have used them too so you know its good.
Posted: Sat May 03, 2008 10:44 pm
by Okibi
I'm happy with my racing beat adjustable sways.
Posted: Sun May 04, 2008 8:17 pm
by Steampunk
I'll be at the dodgy day around 1pm.
We can always set up a time during the week/weekend beforehand though if you like.
I should be at the Macleans Bridge Mothers' day show'n'shine next Sunday too.
N*Power sells adjustable whitelines, contact them and I'm sure they will give you a good deal.
Be patient and don't buy anything until you have a drive in mine, cause if you like how mine handles, then all you need is a front one.
Posted: Mon May 05, 2008 1:52 am
by MxJadeMonkey
Correct if wrong, which i'm fairly sure i am not, super pro and whiteline D bushes are both made on site at Fulcrum? evesham street marooka?
so same bushes just different colour!
Posted: Mon May 05, 2008 10:38 am
by Fatty
i bought adjustable signature sways front and rear with superpro bushes. adjustable is the way to go, it's only a little bit more expensive but it allows you so much more tuning flexibility.
