Brake pad taper
- fattima
Brake pad taper
On my NA6 I'm noticed the outer pad is getting a taper to it, they taper to the out side of the rotor. I presume this could be some play in the caliper sliders or caliper flex (the sliders and greased don't bind). If it is play in the caliper is it possible to bush the caliper bracket so the slider runs straighter? Any suggestions?
Brake pad taper
every ounce counts
- Caffeine
Brake pad taper
wun911 wrote:Does it have anything to do with this??
http://www.stoptech.com/tech_info/wp_knockback.shtml
Floating calipers don't suffer from knockback...
- emexv
Brake pad taper
I just changed my NA6 brake pads and there was no taper on the pads (about half worn).
Mark
Mark
