14\" tyre question
- chrislevingston
14\" tyre question
Gentle forum folks,
The Yokohama A539s on our NA6 need replacement, but are no longer made.
What do you folks still running 14\" wheels suggest in 185/60/14 82h tyres?
A friend has Kumho Ku31s, which replaced his 15\" A539s, says that they are as good as the A539s, but they are not made in a 14\" versions.
TIA,
Chris
TIA,
Chris
- Wuey
- nath
- chrislevingston
i have c-drives on my 14's but have done very little driving on them yet. initial impressions - they were quite, smooth and grippy .. a very good road tyre but i have yet to really push them to the limit. i also have c-drives on my 15's and i have done a lot more driving on this set. in my experience the 15\" c-drives are a very good tyre in wet conditions, and in normal temperatures. however on a hot day / hot road surface they tend to lose a lot of their grip. same goes for track, they don't seem to have a lot of grip.
given that i will eventually be using my 14\" rims more often than my 15s', i'll probably end up going for the adrenalins when the time comes to replace the 14\" c drives, given that my experience with the 15\" c drives has been a bit mixed. in my opinion they are not really the \"all rounder\" tyre that my research led me to believe they would be.... but who knows, maybe the 14\" ones are better than the 15\" ones.. different sidewall height / stiffness, and other factors, could make a big difference i suppose.
- Steampunk
Curly wrote:I'm happy with the Bridgestone G3s on mine, but the rears are starting to look a little low, so I see a set of Adrenalines in my future...
X2
Done a few hundred k's and one track day and they look near-new.
Lots of grip on the track, but then again, my car is a neutral handler.
Very confident in wet weather.
RaYmO wrote:It's a pity you can't get the G3's anymore
Still available on the Bridgestone website in 185/60/14?
http://www.bridgestone.com.au/tyresearch/TyreResult.aspx?width=185&aspect=60&rim=14&load=82&speed=H%20%20%20%20&type=PSR
My current tyres hate the wet weather so I will also be looking out for another set soon.
mr_rotary wrote:RaYmO wrote:It's a pity you can't get the G3's anymore
Yeah I bought some about four months ago. Good value and perform well. Adrenalines will be my next tyre though.
- kitkat
Re: 14\" tyre question
chrislevingston wrote:A friend has Kumho Ku31s, which replaced his 15" A539s, says that they are as good as the A539s, but they are not made in a 14" versions.
C-drives replaced A539's... C's were better in the wet. Replaced C's with Kuhmo Solus (kh15 i think), have slightly less grip but alot cheaper.
- chrislevingston
- chrislevingston
- Kvision
- chrislevingston
Users browsing this forum: Bing [Bot] and 380 guests
