Which Brake Fluid For Road and Track?
eastla
Postby eastla » Wed Apr 16, 2008 7:23 pm
Hi,
I am heading to the track with my NC.
I would like to put in some heat resistant brake fluid.
Is Motul Dot 5.1 suitable?
What other fluids do you reccomend?
2007 MX5 LE
Fatty
Postby Fatty » Wed Apr 16, 2008 7:49 pm
i use motul rbf600 for street and track. very good stuff, i have ended up with glazed pads at my last 3 track meets, but the fluid has never boiled.
it's a bit exxy tho.
Matty
Postby Matty » Wed Apr 16, 2008 9:03 pm
Just put in PBR BF-600 which is about the same as the above.
eastla
Postby eastla » Wed Apr 16, 2008 9:18 pm
Thanks guys.
Will have a look at those fluids and give it a go.
2007 MX5 LE
JBT
Postby JBT » Wed Apr 16, 2008 10:20 pm
You'll probably find the stuff that's already in there will be fine.
eastla
Postby eastla » Wed Apr 16, 2008 10:26 pm
JBT wrote:You'll probably find the stuff that's already in there will be fine.
Dont think so.
I can get the brakes to fade with a spirited drive through the suburbs ;)
Definitely need to get some new brake fluid.
2007 MX5 LE
Fatty
Postby Fatty » Wed Apr 16, 2008 10:28 pm
we only have 1 regular competitor in an NC at our vic track days, he seems to be doing fine with his standard set up. it would be great if you joined up for some competition tho, i'm sure he'd like a challenge. he managed to beat all the other nc's at the winton natmeet track day so be warned he is a good steerer 8)
JBT
Postby JBT » Wed Apr 16, 2008 10:28 pm
eastla wrote:I can get the brakes to fade with a spirited drive through the suburbs ;)
:shock:
Boags
Postby Boags » Wed Apr 16, 2008 10:30 pm
:shock:
:shock: :shock:
What pads?
JBT
Postby JBT » Wed Apr 16, 2008 10:39 pm
Fatty wrote: he managed to beat all the other nc's at the winton natmeet track day so be warned he is a good steerer 8)
Ahem....a Qld car won standard NC at NatMeet track day......also on standard pads and fluid.
eastla
Postby eastla » Wed Apr 16, 2008 10:55 pm
I am running stock pads at the moment.
The only mod I have done to my car to date is Tein Super Streets.
When I had the car at Broadford during the Mazda Drive day I found that I was getting some brake fade up the back straight at around 165kph.
Funny thing is that I got less there than in the suburbs.
I am off to Winton in a few weeks so wanted to change the fluid prior to that and try and avoid fade if I can.
I have two friends with NC's who do not ever seem to get fade (stock pads/fluid).
I do however push quite a bit harder than them.
2007 MX5 LE
eastla
Postby eastla » Wed Apr 16, 2008 10:57 pm
Fatty wrote:we only have 1 regular competitor in an NC at our vic track days, he seems to be doing fine with his standard set up. it would be great if you joined up for some competition tho, i'm sure he'd like a challenge. he managed to beat all the other nc's at the winton natmeet track day so be warned he is a good steerer 8)
I have only had the NC since late 07 so I dont really know the MX5 scene too well yet.
What do you mean when you refer to "our vic track days" ?
2007 MX5 LE
Fatty
Postby Fatty » Wed Apr 16, 2008 11:02 pm
sorry if i have my facts wrong.
there was 2 comps at natmeet, afaik. 1 for the natmeet folk, and 1 for the vic motorsport folk who were just there for the track day (not part of natmeet). i think he was the fastest NC on the day, but was not part of the "natmeet" comp per se.
i could be wrong (i often am )
:oops: :roll:
Fatty
Postby Fatty » Wed Apr 16, 2008 11:06 pm
eastla wrote:What do you mean when you refer to "our vic track days" ?
the vic mx5 club has regular sprints at local tracks ( phillip island, winton, sandown, calder etc ) , i strongly suggest you join in on the fun!!!! send me a pm with your email address and i will send you all the details.
eastla
Postby eastla » Wed Apr 16, 2008 11:49 pm
I think Ill stick with the Dot 4.
I have a feeling that it may be safer than the Dot 5.1
From what I was told by the service department at Mazda; Dot 3 or 4 is recommended but not 5.1.
I dont want to damage anything.
2007 MX5 LE
